Where or how to modify toyota driveshafts?
Currently have a pair of landcruiser prado driveshafts need to be modified to fit a suzuki, both seem to be same length? think they need to be shortened any one out there know where i can get this done around the auckland region??
- niblik
- Sausage Shack
Re: Where or how to modify toyota driveshafts?
you know anyone with a lathe?
it can be done pretty easily if spun up 'true' in a lathe and the end machined of, end uni taken out, pipe adjusted to correct length, uni put back in and zipped back up.. i've modified mine that way... although i went to longer driveshafts but the principals the same...
- mudlva
see Russel at drive shaft services East tamaki off Kerwin ave
092731532
ADL auto parts 129 sunnybrae rd glenfield 4441844
Beaty drive shafts in wiri did my pto shaft, good job and fast, they are just off ash road.
ok thanks will ring around.
mudmike wrote:Beaty drive shafts in wiri did my pto shaft, good job and fast, they are just off ash road.
ditto what he said me and torick used to use them to get stuff done on the roadsweepers back when we used to do that sort of thing
my 4wd is not a truck
