Where Can I take Leaf spring to be reset
Hey...
I have one very badly sagged spring / so bad that I have an extended shackel giving 1.5" of lift to compensate and level the truck out ...
the spring sagged is the rear drivers-side...
Can anyone tell me Who will do spring reset in Wellington area .. and what sort of cost involved for 1 spring
... thanks
... thanks
- its_that_guy2
Re: Where Can I take Leaf spring to be reset
crizpy wrote:Hey...
... thanks
dunno about price but back a few years i had my ones reset lower in my old falcon ...
had it dome by j.d mclennons by melling bridge there ...
you can only but ask i guess if they cant do it .. im sure they will point you in the direction of someone that can
inghams on hutt rd have done mine in the past
thanks for the replys... I rang ingums and he can have a look for me when i get a chance to swing by His rough quote for a pair of springs was $350 However i should be able to get away with one reset as the other side is still standing tall , i tried searching yellow pages and google for a j.d mclennon and didnt have luck .. maybe have gone or name changed..
- curly12
crizpy wrote:thanks for the replys... I rang ingums and he can have a look for me when i get a chance to swing by His rough quote for a pair of springs was $350 However i should be able to get away with one reset as the other side is still standing tall , i tried searching yellow pages and google for a j.d mclennon and didnt have luck .. maybe have gone or name changed..
Get the quote in writing. I didn't and they tried to charge me twice what was quoted.
For that sort of money you could go new
It wouldnt hurt to check out the price of OME springs from grant guy if your spending that sort of money for a reset, I think I paid about $200 each for my front ones a few years back, they were the dakkar ones made in Mayalisa not the origional Aussie made ones
Sadam_Husain wrote:It wouldnt hurt to check out the price of OME springs from grant guy if your spending that sort of money for a reset, I think I paid about $200 each for my front ones a few years back, they were the dakkar ones made in Mayalisa not the origional Aussie made ones
thanks for suggestion...
New springs would be Nice Only prob is I Think my springs are 3"
and think they are EFS But stickers have perished ...
although I might hunt round and see If i can get a single or pair of efs springs before i go with a reset.
curly12 wrote:crizpy wrote:thanks for the replys... I rang ingums and he can have a look for me when i get a chance to swing by His rough quote for a pair of springs was $350 However i should be able to get away with one reset as the other side is still standing tall , i tried searching yellow pages and google for a j.d mclennon and didnt have luck .. maybe have gone or name changed..
Get the quote in writing. I didn't and they tried to charge me twice what was quoted.![]()
Thanks ... i will do if I go the reset path
Could also try Superior Springs
on another line of thought.
Are the springs installed on the right sides?
I know that Suzuki's can suffer from what is called the Suzuki lean. makes them look like one spring is badly sagged. it is caused by the springs being different spring rates and being installed on the wrong sides , drivers side has a higher rate to handle driver , battery , fuel tanks etc etc which are all on the same side.
Don't know if this would apply to Cruisers being a much heavier vehicle, but food for thought.
LR110 ..... LJ50 project
Rod Longsdale in the Waiarapa (featherston 4x4 club) has the gear to reset them and he is willing to show you as well.... don't have his number hands but he is in the phone book.
here is mclennans number
04-570 8010
http://yellow.co.nz/whitepages/Lower-Hu ... 9_BUS.html
ive been told how to do it but i have not tried it yet. my chop needs a bit of spring sag so i will try it soon, basicly you split all the leaves then methodicly hammer along the spring over two higher points so ypou can introduce a new curve to the spring. apparently you need to measure each leave to make sure the curves are similar in profile to each other and you mark the shape on the bench in chalk to match them all together. i will check with my mate who told me about it and let you know. i also checked with inghams on hutt road and it was comparable to buying replacements. so basically if you can do it yourself it is worth reseting otherwise buying new ones is probably easier and at least you know they will work first time rather than paying a similar price imo
DIRTY OLD HILUX
022 519 7700
022 519 7700
04-570 8010
They also trade as Airport Equipment
mf kings used to do them.not sure if they are still around .were down in gear st petone from memory
one spring should be about a hundy i would have thought
DIRTY OLD HILUX
022 519 7700
022 519 7700
sig wrote:mf kings used to do them.not sure if they are still around .were down in gear st petone from memory
They are now in Wingate, Plikington St, left hand side heading north.
