can i lock my front diff up (weld)
hi iv got a 92 ln130 surf and was wondering can i weld up my front diff.its not a solid beam axel front so just want to make it get as much traction as i can without breaking to many cv's.thanks.all help will be good + or -
- Bulletproof
Re: can i lock my front diff up (weld)
bdog012 wrote:hi iv got a 92 ln130 surf and was wondering can i weld up my front diff.its not a solid beam axel front so just want to make it get as much traction as i can without breaking to many cv's.thanks.all help will be good + or -
Hope you are not going to drive it on the road because you can't steer and wont get a WOF
Even as a trailer Queen I still wouldnt do it as you can't turn tight
Richard
Never say die, up man and try
Bulletproof wrote:bdog012 wrote:hi iv got a 92 ln130 surf and was wondering can i weld up my front diff.its not a solid beam axel front so just want to make it get as much traction as i can without breaking to many cv's.thanks.all help will be good + or -
Richard
and you will put more pressure on your cvs
- rangimotors
Richard
with a set of manual hubs on it I can't see how it could change anything on road (assuming in 2wd) you will also probably find that you will get a wof, I have never found a wof guy that ever checks a truck in 4wd. However it is a very rangi way of doing things, it will drive like crap off road and proves to be very dangerous when trying to go down a steep hill with a sharp turn at the top. I found it hairy enough in my old truck with an auto locker and would hate to think what a welded diff would be like. Chances of you smashing cv's will increase ten fold so not a great idea. Keep it open for the mean time and the money you save in cv's will pay for an auto locker in no time.
Just my 2cents
Ps. If you are smashing cv's at the mo with an open diff wind the torsions back a bit and drop the truck lower if you can, it will decrease the angle on the cv and make it last longer
What Rangimotors said^^
sweet as sounds like i wont be doing that then.does any one no were i can get a air locka from.and does any one know who sells them in chch.or does any one know who sells the chinese ones im keen to try one and see what they go like thanks for the replys.
mines welded in the front, its independant 2. never broken a cv, they seem 2 b alot stronger than solid front. snapped drivers side axel at the diff but that was when i was buried deep as in clay trying 2 winch up a 2 meter incline and clutchin it hard. otherwise drives good off road huge difference 2 single spinner goes anywhere now.
yea i just replaced both diffs and i welded my front 1 up and holy f*#k wot a difference real happy i did it and put a lsd in the back she goes lika dream now hahahaha would recommend it to any one
