50mm lift double cab lux
Hi guys
looknig at doing a 50mm lift in my lux its a 97 double cab ute, have seen the maxitrac leafs but havent read much good stuff about them, what else is there?
How about shackles? or getting leafs reset 50mm higher?
Re: 50mm lift double cab lux
What bad things have you heard about maxitrac springs? I've got them front and rear in my surf and they seem to have been ok the last two years. Nice and flexy now, only problem with mine is the drivers side is slightly lower although i do a lot of solo driving and i'm a 150kg bastard
I've got no complaints about my EFS liftkit in my Hilux although its probably almost double the cost of Maxitrac,
EFS has a 3 year warranty and is all Australian made.
OME leaf springs are Taiwanese now
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
[quote="nstacey"]I've got no complaints about my EFS liftkit in my Hilux although its probably almost double the cost of Maxitrac,
OME leaf springs are made under licence in MALAYSIA now[/quot
badnuz wrote:nstacey wrote:I've got no complaints about my EFS liftkit in my Hilux although its probably almost double the cost of Maxitrac,
Whoops my bad
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
- rangimotors
same as many things for a bolt in product the more you spend the better it will be. Maxitrac are cheap and do the job with no major issues, they are pretty hard but you can always swap a few springs around or get rid of the load leaves.
thanks guys,
just read that they dont sit evenly.
would it be better to get the standard leaves reset?
more expensive?
more expensive?
getting the leaves in my surf reset was more expensive than getting a set of 50mm maxitrac leaves. although when i bought them i asked repco for a trade discount and they said yep.
how much was it for a full set for you lux?
$500 for the set of leaf springs . think retail is about $800. i went to repco in pukekohe and said my mate could get me a trade discount and the dude said dont worry il hook you up anyway. dunno if they just wanted to make a sale or if he was just a good fulla
the quote i got just to reset the standard springs was $550
500 for all 4?
yep sure was. all 4
i got quoted 800 on trade
for real? that sux, i must have just got the right fulla on the right day
Landscaper
- Driver/Navigator
Ive got maxi trax 50mm lifted leafes in my bounty ute good price and works well all i did was cut my overload leafs down buy about half to increase flex did it fitted cut buy cut so as to see results on ramp all good
