Hi
I removed a tyre valve with the help of some rocks on the weekend on the coast.
I had spare valve with me but struggled to find anyone open that would change it for me....
Does anyone know where I can get the tools to remove and refit a tyre in the bush?
thanks
Tyre Removal tools
Re: Tyre Removal tools
A High Lift Jack is you friend for breaking the bead.
A spade is handy for leavering the tyre down far enough so you can sneak your hand in and push the new valve through enough to get hold of it from the outside.
You could always buy a set of tyre leavers instead of the spade.
Thats how I do it in the bush anyways.
Anything to do with tyres in the bush is a drama
supercheap had some nice steel tyres irons got three for about $36 first time i repaired a tube put a big hole init with the irons second time prefeced the idea still holding air
- Bulletproof
Why don't you just carry a tube and with a hi lift easy to fit
Cheers Richard
Cheers Richard
Never say die, up man and try
have to agree, a hilift jack is a very versatile tool, try a tyre first at home just to practise rather than doing it for the first time in the bush
didn't have spare tubes then have now , but learned something as well so was a win
Take the tyre off, let the air out (if any still in), lay trye down, drive another truck over the edge of the tyre to pop the bead. Put a little grease around the valve stem and pull through with a set of pliers. Use a cargo starp to push bead around rim to seal and air up. I carry a dive cylinder just for this reason.
Al
Al
