as some of you may know i blew my front diff bout a week ago, am jst starting to get it sorted out and am thinking about a looker to stop it happening again. what are ppls opinions of them ie whats good whats not, whats the cheapest. is this a good idea??? at the moment looking at a lockright that mike suggested
cheers Pete
lockers
- mike
- Last minute Mike
you wont need to replace the ADD setup but if you fit manual hubs it would be easier. Currently I run around with the ADD setup and fixed hubs with a lockrite in. All you experience is a slight pull to the right as the right front drive shaft is still connected and carries the load of the whole diff and popshaft. The locker causes the diffhead to turn now as opposed to the open diff only the spiders turned. For long trips I just replace my right drive flange with one that does not have a spline.
Mike
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
