Escudo diff gears
For all Suzuki related topics
suzookyman
Escudo diff gears
Post by suzookyman »
hi, can anyone tell me if the pinion gear in the 1600 auto
is the same as in the manual? cheers Al
ONOescudo
Re: Escudo diff gears
Post by ONOescudo »
Autos have a slightly higher diff ratio than the manual.
5.12 to 1 manual
4.8 to 1 auto
Some thing like that.
Cheers MIKE.
suzookyman
yeah im currently running man box with auto diffs and have been given
manual rear and man front but pinion gears are chipped i have 3 auto front diff spares so was hoping (ho ping?) a good man out of the lot..
ONOescudo
Post by ONOescudo »
Yes bit of a prop there.
Vitara/Escudo do suffer from being geared to tall.
If you need to buy some manual diff gears it will change you’r over all ratio, But not as much as lower transfer case gears. Which I am currently doing to my 1600 8 valve. Think its about NZ$1000, from memory. (Bad memory)
But iv got 5.1 manual gears any way.
Cheers MIKE
Rotazuk
Post by Rotazuk »
All the 16v 1600 auto's I looked at all had 5.12 gears . I have not found any yet ( one sitting at pick a part but no time to check :( ) but I have been told it is only the 1600 carb 3sp auto's that had 4.62 gears .
So you most probably have all 5.12's .
Chris
Return to “Suzuki”
