Safari front diff seal
For all Nissan related topics
mudtroll
Post by mudtroll »
It looks like the inner axel shaft inner oil seal is leaking, oil dripping from lower bearing cap on the swivel hub. Anybody done one of these? Any tricks or tips? According to my manual I need a slide hammer to get the seal out or can I dig it out with a screwdriver or similar?
darinz
Re: Safari front diff seal
Post by darinz »
They are pretty tricky to get at so slide hammer makes it MUCH easier. But you can probably do it without. I've done one without a slide hammer but didn't start the other side until I had the right tools.
mudtroll
Post by mudtroll »
darinz wrote:They are pretty tricky to get at so slide hammer makes it MUCH easier. But you can probably do it without. I've done one without a slide hammer but didn't start the other side until I had the right tools.
Taking your advice I splashed out on a supacheapy $18, hope it dosen't break!
mudtroll
Post by mudtroll »
El cheapo slide hammer didn't work so made a hook out of a tent peg worked well :D
Nissan wanted $68 for seal, auck bearings $10.
Hombrey
Post by Hombrey »
Yeah i doubt you'll get the seal with a screw driver. I tacked a lug onto a bit of box section with a short piece of box welded to the other end. hooked the seal with the lug and tapped the block at the other end of box to draw the seal out. do one side with it jacked up to stop the chance of loosing diff oil, less your gonna replace it. they are ok to do but just a bit messy!
