Safari front diff seal
Posted: Sun Oct 18, 2009 4:56 pm
by mudtroll
It looks like the inner axel shaft inner oil seal is leaking, oil dripping from lower bearing cap on the swivel hub. Anybody done one of these? Any tricks or tips? According to my manual I need a slide hammer to get the seal out or can I dig it out with a screwdriver or similar?
Re: Safari front diff seal
Posted: Mon Oct 19, 2009 1:31 pm
by darinz
They are pretty tricky to get at so slide hammer makes it MUCH easier. But you can probably do it without. I've done one without a slide hammer but didn't start the other side until I had the right tools.
Posted: Mon Oct 19, 2009 4:42 pm
by mudtroll
darinz wrote:They are pretty tricky to get at so slide hammer makes it MUCH easier. But you can probably do it without. I've done one without a slide hammer but didn't start the other side until I had the right tools.
Taking your advice I splashed out on a supacheapy $18, hope it dosen't break!
Posted: Tue Oct 20, 2009 4:38 pm
by mudtroll
El cheapo slide hammer didn't work so made a hook out of a tent peg worked well
Nissan wanted $68 for seal, auck bearings $10.
Posted: Tue Oct 20, 2009 8:29 pm
by Hombrey
Yeah i doubt you'll get the seal with a screw driver. I tacked a lug onto a bit of box section with a short piece of box welded to the other end. hooked the seal with the lug and tapped the block at the other end of box to draw the seal out. do one side with it jacked up to stop the chance of loosing diff oil, less your gonna replace it. they are ok to do but just a bit messy!
