help with r series box
Posted: Mon Oct 19, 2009 6:33 pm
by hiace007
have just put a 1kzte with a r150 box into my 87 surf and it is stuk in 4 wheel drive is it electronicly controlled as i see it has sum electronics on it and if so what wires/ pins go whea?
Re: help with r series box
Posted: Mon Oct 19, 2009 6:41 pm
by Jerry
What was the donor motor/box/tcase out of?, if it was a prado it will vacuum operated (there are 2 vacuum solenoids on the firewall usually)
Posted: Mon Oct 19, 2009 6:49 pm
by hiace007
motor supercustom van and box from toyota comercial wrecker its a r150 arnt they out of a v6 surf?
Posted: Mon Oct 19, 2009 7:34 pm
by Jerry
Posted: Mon Oct 19, 2009 8:04 pm
by hiace007
thanx so you reken i shud jus get manual hubs to solve this problem
Posted: Mon Oct 19, 2009 9:45 pm
by GotFlex
yes but your driveshaft will still spin, my mates is like that at the moment too, he has the little dog gear out of the transfer so only 2wd, we just gota wire in the module thing as his is electric
Posted: Tue Oct 20, 2009 6:00 pm
by hiace007
yea i compared with a surf today it is electric not vacum his has a button on the 4wd stick jus pres it with out moving the 4wd gear stick and it locks the front got my box from wrecker with out loom or the button on the gearstick does any one in wellington know how to wire this up
Posted: Tue Oct 20, 2009 6:13 pm
by Bulletproof
I run one of these boxes and they have an electric Worm drive motor on the back of the transfer case so is probably locked in.
Normally they are operated by an electric knob on the gear lever which winds them in and out. The motor quite often gives trouble and can get stuck in 4 wheel drive.
I have converted mine to air operated. Others fit a manual lever or else you need to get the wiring sorted to make it work properly.
They are a bloody good box
Cheers Richard
Posted: Tue Oct 20, 2009 6:40 pm
by hiace007
the lever sounds like the go but what was involved with the air operated one
