Seatbelt mount question
Posted: Thu Oct 22, 2009 1:20 pm
by 63swb
Hi,
Does anyone have a series landrover that has seatbelts mounted in a way that the top can be removed? I have a series one that has seatbelts mounted to a roll bar, I want to be able to drive my series 2 with no top but I cant think of a way to mount the belts and i dont want to put a roll bar in. any help / pictures would be great!
thanks
Re: Seatbelt mount question
Posted: Thu Oct 22, 2009 1:22 pm
by Bolo
63swb wrote:Hi,
thanks
Would Lap belts work... ( bolt down to the floor )
Posted: Thu Oct 22, 2009 1:27 pm
by 63swb
Lap belts would work fine, im just not sure if they are legal in the drivers seat??
Posted: Thu Oct 22, 2009 1:40 pm
by Bolo
Maybe have a look around here they mite know ,http://www.ltsa.govt.nz/
Posted: Thu Oct 22, 2009 3:30 pm
by aroma
my jeep has lap belts for the front seat no way to fit lap and dia
if they came out with lap belts and have not been changed or rather the ltsa computer for your vehicle been changed to lap and dia you should be ok ask your wof man if no one can help you on here
Posted: Thu Oct 22, 2009 4:14 pm
by tallsam66
The type of seat belt you require depends on what type were original equipment when the vehicle was first registered.
As a side issue i wouldnt be doing ay 4wding without a roof & NO rollbar....if you roll it youll be dead !!! as happened in canty last yr in a cut down surf.
Posted: Thu Oct 22, 2009 5:22 pm
by 63swb
Im not sure what it was originally but maybe i will go down to a vtnz or somewhere and ask there. As far as 4wding goes this vehicle is going to be for road use, got a safari and the series one for playing in the mud
Posted: Sun Nov 01, 2009 8:39 pm
by gary_in_nz
hey mate, you should be ok with lap belts for the rover as its part of the original manufacturer equipment, as they were from factory, some had lap belts.
land rovers are just meccano for big boys and just mix and match real easy, so over the years the wof guys wont know what your particular rover came out with from the factory.
Posted: Sun Nov 01, 2009 9:39 pm
by motorhead
My 69 has a factory mount point on top of the bulkhead just behind the drivers right shoulder and of course pass left. If pics needed let me know.
Posted: Mon Nov 02, 2009 10:29 am
by 63swb
thanks for all the help so far, sounds like its not going to be too much of a major issue
