Lights not working on lowbeam
- wgtnnewbie
Hey guys went whilst out last night I discovered that my headlights aren't working on lowbeam. Tried changing bulbs today but still no lowbeam. They work fine on high beam. Does anyone have any ideas as to the cause of this.
cheers steve
cheers steve
Re: Lights not working on lowbeam
if you stop blocking the sun you wont need headlights............
WARNING:
fuses? Relays?
Cheers Daniel
Cheers Daniel
- wgtnnewbie
Lynx wrote:fuses? Relays?
Cheers Daniel
checked fuses and they all appear to be fine and swapping the relays around didn't fix the problem. I'm wondering if it could be the steering column switch or a loose wire some where.
Well if all checks out ok, sounds like a switch , or lose(cut ) wire
loose nut at the wheel?????
WARNING:
taz01 wrote:loose nut at the wheel?????
o yep thats it forsure , yea that will cause a problem as well
- hilux andy
- Driver/Navigator
wgtnnewbie wrote:Hey guys went whilst out last night I discovered that my headlights aren't working on lowbeam. Tried changing bulbs today but still no lowbeam. They work fine on high beam. Does anyone have any ideas as to the cause of this.
cheers steve
I have the opposite problem, my highbeam doesn't go. I am thinking something to do with the stalk
check that all your earth wires are good too
- hilux andy
- Driver/Navigator
mine was the stalk, a pin had come out the end releasing a spring and ball bearing. 3 stage switch of which 2 still contacted ,but not the 3rd. All good now for the WOF man.
- wgtnnewbie
well tried another stalk unit and still no lowbeam looks like a trip to the auto sparkies. can anyone reccomend a good cheap auto sparky in the lower hutt area? cheers guys Need to have the truck up and wofed for anniversary weekend...lol (insert tui ad here)
wgtnnewbie wrote:well tried another stalk unit and still no lowbeam looks like a trip to the auto sparkies. can anyone reccomend a good cheap auto sparky in the lower hutt area? cheers guys Need to have the truck up and wofed for anniversary weekend...lol (insert tui ad here)
Bill Blackwell in Upper Hutt.. Or Marks Auto Electral in Taita
hey go and see mark at g guys he is the auto sparky sharing the workshop, it was his old drive, i brought it from him, he may know what the problem is quickly, i still got the front stabi bat at my place, do you still want it or should i biff it?
Take it to Graham, he can sort that out whilst he does the wof
wgtnnewbie wrote:Need to have the truck up and wofed for anniversary weekend...lol (insert tui ad here)
are you a kiwi member?....... there maybe invites sent out but not at this stage
WARNING:
- wgtnnewbie
taz01 wrote:wgtnnewbie wrote:Need to have the truck up and wofed for anniversary weekend...lol (insert tui ad here)
what if i payed my fees on the day.... would that work????
