1KZ-TE TIMING ISSUE??
Posted: Wed Nov 04, 2009 9:47 am
by pradon35s
HI
I HAVE A 93 KZJ78 PRADO WITH THE 1KZ-TE MOTOR.
IT HAS AN INTERMITTANT ISSUE WHERE IT IS DRIVING FINE AND THEN IF I STOP AT LIGHTS AND IT IS IDLING FOR MORE THAN SAY A MINUTE IT STARTS TO KNOCK, ALMOST LIKE A BOTTOM END BLOWEN KNOCK BUT HAVE BEEN TOLD ITS THE INJECTION TIMING, ALSO THE CHECK ENGINE LIGHT COMES ON. BUT THEN IF U TAKE OFF AS SOON AS ITS UNDER LOAD ITS OK.
THERE IS A SENOR ON THE INTAKE SIDE OF THE BLOCK, DOWN THE BOTTOM NEAR THE TRANSMISSION, 2 PIN PLUG, IM GUESSING A KNOCK SENSOR? THIS PULG WAS BROKEN AND IS WAT STARTED THE ISSUE I THINK, I HAVE SINCE REPLACED THIS SENSOR AND THE PLUG THAT GOES ON IT BUT STILL NO CHANGE.
ANY HELP WOULD BE MINT
CHEERS
Re: 1KZ-TE TIMING ISSUE??
Posted: Wed Nov 04, 2009 10:40 am
by 4WDbits
The timing is computer controlled (can't remember the exact terminology in the wiring diagram).
Posted: Wed Nov 04, 2009 2:59 pm
by Landy Rover
Really should go to garage with scanner to check the fault codes that will be stored as a result of the check engine light going on. It could be many things wrong, eg temp sensor, MAP sensor, TP sensor, even injection pump. Save yourself the headache of replacing stuff that doesnt need to be
Posted: Thu Nov 05, 2009 8:53 am
by pradon35s
awsome,
cheers for ur help guys i had no idea they could be scanned il go get that done today!!
thanks for ur help!
forum once again saves me $100s.....
Posted: Thu Nov 05, 2009 6:23 pm
by UBZ
their should be a mark on the block near the front of the fuel pump that the pump lines up to initially set the fuel timing from factory.
does the engine warning light come on and stay on when you start the truck?
has the battery been disconnected since the sensor was damaged.
Disconnecting the battery will clear the fault codes in the ECU.
Pretty sure it is the crank position sensor down the bottom. Was it replaced with a Toyota Genuine Part.
Posted: Fri Nov 06, 2009 9:11 am
by 1rugger
there will also be two wires in the diagnostic plug you can short out and read the faults you're self if you can get you're hands on a manual for the truck it will tell you how to do it and what the codes (flashes of check eng light) correspond to.
Posted: Fri Nov 06, 2009 3:13 pm
by Jerry
I've got a downloaded toyota manual if you need it, it lists the diagnostic functions as well as where all the sensor thingys are..... its only 14mb (can try and email if you arent on dial up etc)
Posted: Sat Nov 07, 2009 3:42 pm
by pradon35s
yes i heard bout the flash codes, iv tried getting my hands on a manual but every1 seems to say they dont exsist for these??
engine check light comes on when timing goes out and knocking starts but it is intermittant but kinda getting worse.
jerry, if u could email me the manual that would be awsome?
adam.lange@live.com
Posted: Sat Nov 07, 2009 5:07 pm
by tallsam66
You can diagnose the fault codes yourself....its very easy.
Go to the following website & check it out.
http://www.ncttora.com/fsm/1KZ-TE%20Engine%20Manual/hilux/info/manuals/1KZ-TE/index.htmlBasically get a small piece of wire & with the key turned off connect terminals TE1 & E1 together.
Then turn on the key...the check engine light will flash & tell the the error codes.
Posted: Wed Nov 25, 2009 5:07 pm
by pradon35s
i went through the manual understanding it as best i could..
bridged the terminals and took fault codes from ecu..
gave me flash codes..
one flash, two flashes.. code 12 im guessing??
Engine Speed Sensor.. which is the sensor that i thought was knock sensor.
i have since replaced the sensor and there was dodgey loom going to it so replaced the plug and wiring.
started it up. still no change..
disconnected battery for 10min to reset codes??
still no change, noise is now worse, timing seems to be out as soon as i start it up and stays out is not intermittant anymore..
im stumped for ideas....
ECU??
Posted: Wed Nov 25, 2009 5:32 pm
by UBZ
First thoughts that come to mind.
jumped a tooth on the timing belt?
or injector pump has moved position in relation to the block.
or the wiring fault is further up the loom , have you done a continuity check from the sensor back to the ECU?
