anyone have something??? its like the last little bit i need then its all go
WANTED 80 SERIES BIT
Hi all, i need a new ( or good secondhand) power-steering reservoir for my almost finished 80... mine is weeping at the seems ( as they do)
- skid
- Tyre Man
Re: WANTED 80 SERIES BIT
badnuz wrote:Hi all, i need a new ( or good secondhand) power-steering reservoir for my almost finished 80... mine is weeping at the seems ( as they do)
anyone have something??? its like the last little bit i need then its all go![]()
make one
I'll give you mine if I can have your pump
get one off a surf, they have the rubber feet to stop the vibration cracking that you have, modify the bracket slightly and your good to go, bout 10 buks from a wrecker?
best to fix the problem rather than just replace it and wait for it to happen again eh
- MNC
Not sure how bad your leak is but I've been using the stop leak fluid in mine which has helped.
- firestonecruiser
i have the same problem with my pump. wat year and model surf power steer pump do you need
firestonecruiser wrote:i have the same problem with my pump. wat year and model surf power steer pump do you need
pump or Reservoir ?
the surf fluid Reservoir has rubber feet on it to absorb the vibrations which cause cracks, any surf as far ais im aware all have the rubber feet, you need to modify the bracket slightly to make all the feet/bolt holes line up but worth it in the long run
