How do you top up auto trans fluid on a 95 vitara ?
is it thru the gearbox dip-stick hole?
auto trans top-up 95 vitara
Re: auto trans top-up 95 vitara
that is the way you top up most auto transmissions did you check the fluid level while the engine was running
my 4wd is not a truck
mercutio wrote: did you check the fluid level while the engine was running
yeah we did
never topped a auto up before, always had manuals
thank you mercutio
