Sister in Laws Pajero won't idle, has been suggested that it is because of the Idle Speed Sensor.
Does anyone have one spare?
Or any other suggestions as to why it won't idle?
Sometimes its fine(not often), sometimes idles at 1500RPM, but most times it doesn't idle at all.
Also her speedo has stopped working and she has asked for a wiring diagram and any hints as to what may be wrong.
Any help appreciated.
Pajero 3.5 litre, Idle issues, Speedo issues. help
Re: Pajero 3.5 litre, Idle issues, Speedo issues. help
Smurf wrote:Sister in Laws Pajero won't idle, has been suggested that it is because of the Idle Speed Sensor.
My Mates truck usedto do the same thing, i think we wound up the idle a bit to bring it back, and the speedo is cable driven. so it could of come lose or broken.
Can't wind up the idle as occasionally it runs at 1500 rpm already.
Speedo is electronic
Smurf wrote:Can't wind up the idle as occasionally it runs at 1500 rpm already.
Could stick it on a Scan tool to see if fault codes come up and go from there..
its not a fuse blown or anything like that for the speedo?
She has checked all the obvious, fuses etc.
She is a mechanic but hasn't come across this before.
She lives in Reefton and has no access to a diagnostic tool.
You said in your first post that it is suspected as a Idel speed sensor .. have they replaced it??? if not i would try that and the TPS sensor as well
We are trying to find an Idle Speed Sensor,
TPS has been replaced I think
Smurf wrote:We are trying to find an Idle Speed Sensor,
I dont know if there is any difference between the 3000 and the 3500. but i have the 3000 one in my parts truck.. and im not sure if i still have that there.. would need to check.
Bolo wrote:Smurf wrote:We are trying to find an Idle Speed Sensor,
Cool, I'll get back to you once I find out if the 3 and 3.5 litre ones are the same.
How much would you want for it?
HAve you looked at the idle stepper motor? The idle is controlled by the stepper motor than sits under the inliet manifold. Well known for gunking up and not working properly as the crankcase breather is right beside it.
NJV6 wrote:HAve you looked at the idle stepper motor? The idle is controlled by the stepper motor than sits under the inliet manifold. Well known for gunking up and not working properly as the crankcase breather is right beside it.
Chers Glen, will look at that also.
Do you have stepper motor and idle speed sensor that you could part with
- snappalipz
- Newbie
hay dude my pajeros doin same thing a speedo thing is a sender not working ,ital cost me $70 to take out & $90 to service it from a guy in nelson robert fraser shop 6,150 vanguard st nelson ph 5489405,,mind flicks al ova the place every 3 weeks or rund then and makes motor surge abit to. the place is called nelson instrument &control electronics ltd.
