32's on a 2.8 Pajero
northland_pajero
Post by northland_pajero »
I have a 2.8 pajero (1996) I have a set of Safari 15x7 white spoke rims, I a looking at putting a set of 32x11.5x15 tyres on.
Sitting a 32 tyre next to the front wheel the other day they didnt look like they will fit without rubbing.
I have a winch on the front, and that does cause the front to sit a little lower, but the problem looked to be the guards at full lock.
Will 32' fit without having to do a lift?
How do I wind up the torsion bars at the front?
Last edited by northland_pajero on Sat Nov 14, 2009 8:36 am, edited 1 time in total.
madmatt
Re: 32's on a 2.8 Pajero
Post by madmatt »
They will fit, you have a 30mm bodylift as std on the 2.8 so you can fit 33's no worries.
Matt
2011 FJ Cruiser, few mods, more to come
northland_pajero
Thanks for your reply.
Do I need to wind the torsion bars up to make them fit?
madmatt
Post by madmatt »
I doubt it very much unless they have drooped a bit over time. The old man put 32's on his 3.0l which has less clearance than yours and no rubbing at all.
Matt
madmatt
Post by madmatt »
Oops, just saw your edit. With the winch you will probably have to give the front a bit of a crank. Don't bring it to level, Paj's feel a bit more stable with about 15 to 30mm difference in height from front to back, front being lower.
Matt
malfunction
Post by malfunction »
If your only gonna look at 33s max dont body lift it. Buy a set of 50mm lift rear springs for $250 and wind the front torsions up. Much better to do it thru suspension than body lift if you can afford the springs. It will also improve handling. I found mudstar 33s to be perfect on the 2800 deisel as they are a bit thinner than most 33s and allow the 2800 to spin them easier.
Mal
021 0666826
Return to “Tyres”
