Hi guys
Few questions,
Will a 410 body fit on a 413 chassis? will all the body mounts line up?
have a rusty 413 and mint 410 body want to swap over,
Also are the diff heads the same? have a locker I want to put over or if they are different can I just change the crown wheel.
Think thats it for the moment,
410/413 compatability
Re: 410/413 compatability
Couple of the rear mounts behind the seats dont line up quite right, but can be made to work quite easy
410 / 413 diff heads are totally different sizes, as far as i know nothing is interchangeable between them . Lock-right part numbers are different as well.
LR110 ..... LJ50 project
all other mounts line up? whats the trick to getting it to fit?
