stero speakers
aroma
stero speakers
Post by aroma »
right you learned types
have a cd player in the jeep but cant fit 4 inch speakers
spec are max 50w x 4
continuous 22w x 4
load 4 ohms
preout max 2.2V
now can i use a set of computer speakers and what do i need to look for on the sticker
this might as well be a foreign language to me so simple answers please
my speakers have 3.o W x 2
and dc 9 volt :?
thanks
Warren
chrome
Re: stero speakers
Post by chrome »
as long as the ohms (resistance) is the same they will be all good. not sure what power rating computer speakers are tho. have you been to see a car audio shop at all?? maybe they can fit them somewhere else something more suitable maybe
DIRTY OLD HILUX
022 519 7700
malfunction
Re: stero speakers
Post by malfunction »
What model jeep?
Mal
021 0666826
aroma
Re: stero speakers
Post by aroma »
my cj4 have put all coms and stero on bracket above windscreen
have been to stero shop and nothing smaller than 4 " so will go the comp speakers way have seen them cheap in the mall $2 type shops
thanks all
UBZ
Re: stero speakers
Post by UBZ »
very unlikely that the computer speakers will work in a car.
Impedance would be 6-8ohm normally , but being a powered speaker they could be anything.
if you hook them up to a 4ohm head deck they will go bang!
What about building boxes to go behind the seats?
malfunction
Re: stero speakers
You can buy sound bars that mount to roll cages, i have one in my wrangler
Mal
021 0666826
Taz
Re: stero speakers
Post by Taz »
UBZ wrote:very unlikely that the computer speakers will work in a car.
My mate had a Logitech surround sound computer speaker system set up in his Hiace. It can be done. Will ask him about it on the weekend.
malfunction
Re: stero speakers
You can do it thru the pre outs if you stereo has them
Mal
021 0666826
chrome
Re: stero speakers
Post by chrome »
or maybe you can run two speakers per channel im sure that drops the resistance by half. dont quote me on it tho :mrgreen:
DIRTY OLD HILUX
022 519 7700
malfunction
Re: stero speakers
chrome wrote:or maybe you can run two speakers per channel im sure that drops the resistance by half. dont quote me on it tho :mrgreen:
If you use the pre outs on stereo ohms wont mater as it still uses inbuilt amps
Mal
021 0666826
chevrolux
Re: stero speakers
Post by chevrolux »
if they are 9V then you obviously need to bring the 12V down to that. that can be done with a voltage divider but that involoves mucking around. i set up computer speakers in my very first car (corolla). just chopped off the 240v transformer (cos they were 12v comp speakers) and wired in to the cigarette lighter. then wired the front channels from the head unit in to a 3.5mm plug which went in to the sub/amp and from there the speakers plugged in to that. :D what i found was you had to keep the volume quite low on the headunit and use the speakers' volume control to turn it up and down. get some wicked clipping if you crank the headunit volume up :lol: pre-outs would be the way to go. just get one of those rca-3.5mm (or whatever input you have on the speakers). that would probably stop what i experienced but i only had the stock toyota hd.
personally, i would make some speaker boxes for 6x9s/components cos i hate having shit sounds :lol:
UBZ
Re: stero speakers
Post by UBZ »
chevrolux wrote:personally, i would make some speaker boxes for 6x9s/components cos i hate having shit sounds :lol:
my thoughts exactly
aroma
Re: stero speakers
Post by aroma »
oops have been busy but
no room behind the seats and WILL get very wet
roll bar is outside the cab and prob not doing internal but???
have been promised some old computer speakers so will wire them up and
don't expect to hear the stero over 50 or 60 k's due to wind and tyre noise :?
and just relised haven't put compressed caps on my ht cables yet!!!!!!!!!
thanks guys/gals
Heath
Re: stero speakers
Post by Heath »
my thoughts exactly
You could buy mine :D
http://www.trademe.co.nz/Browse/Listing ... =255236159
Buggered if I want to post them though.
Return to “Tool Shed”
