TD42 Not starting help!
For all Nissan related topics
jA-
Post by jA- »
Hi all
this is not the way i wanted my first post to go but shit happens!! :(
i have had this 91 LWB safari for about 3 months now which is slowly getting built up but a sad thing happened this morrning,went to leave for work jumped in and turned the key and was greeted with a very bad sound and it would not start wouldnt even try and fire... i don't get how anything major could of happened as i drove it home from work the night before and it was fine started fine drove fine was fine lol
so i luckly got the day off and first thing i did was bleed it that was fine and didn't make any difference...
taken the sump off checked crank, rods, bores, and what i could see of the pistons... looked fine no braoken bits in the bottom of the sump
took the tappet cover off checked that the cam was working...fine
took the rockers etc off checked the valves were seating.. again all seems fine
so now im lost :x the sound seems to be coming from the rear of the engine but couldn't be sure
i allways do oil and filter changes every 5000km flush every 2nd change...i turboed it about 2 months ago running 12-14psi and no more than 600 EGT...
sorry starter is turning engine over as per normal but the engine will not fire at all...
any help would be awsome... thanks Jacob
Swamped
Re: TD42 Not starting help!
Post by Swamped »
Starter solenoid?? If the starter isn't going, it may be electrical. If the starter is firing but the engine isn't turning over it may not be throwing out correctly?? Somone correct me if I'm wrong.
stinky
House Hubby
Post by stinky »
give the starter a tap with a size 5 multi tool(hamer) had this happen to me before
____________________________
Martin
http://www.wtbs.co.nz
safaripete
Post by safaripete »
where are you located gives more scope to let locals maybe have a look aswell
jA-
Post by jA- »
safaripete wrote:where are you located gives more scope to let locals maybe have a look aswell
done cheers
safaripete
does it even sound like it wants to fire???
if not sorted by friday i could have a looksie
albundy
Rolly Polly
Post by albundy »
What's the sound :?: :?: :?: My first thoughts would have been fuel filter blockage or air in fuel line.
Al
jA-
Post by jA- »
cheers safaripete, i'll keep you's posted um im gona atack it again on the weekend if not after work ( nites ) etc
um the noise well i was expecting to find a lose con rod or sumthing like that when i got the sump off but didn't its that kind of sound... but as for it not going that has me stuffed
its wierd for it to be sweet then the next start not even wana go
oh well hmmmmm
this mite help
http://www.offroadexpress.co.nz/video/bad-sound
albundy
Rolly Polly
Post by albundy »
Not as bad as I was expecting. I have that sound when I turn the motor over without glowing, or really cold day starts. I reckon it's just because there is no oil sitting on the sides of the cylinders. Have you checked the fuel filter and lines for blockages. I reckon your problem will be in this area.
Al
jA-
Post by jA- »
hey guys thanks for all the ideas
got home at lunch time with some engine start gave it some fumes and it fired up streight away, turned it off and tried it wothout engine start nothing, started it up with the engine start and left it runing for a few min's then stopped and tried again without the engine start and it fired up so with it going cracked off the injectors one by one and they all working so stopped it and left it about half hour and tried again and it fired up fine but without the bad noise so how knows what it was...
had new fuel filter about a month ago...
could it be somthing in the injector pump? as i don't think it has had the seals etc done??
oh well glad its going and hope it starts sweet in the morning lol already had enough stick from all my toymota budds :x
thanks again
Jacob
flyingbrick
Post by flyingbrick »
glow plugs not working.
albundy
Rolly Polly
Post by albundy »
At leat it started without having to pull it apart, those toymotoas would all still be in parts and they would still be stumped. Might pay to run a fuel clearner conditioner through it, I am still convinced your problem was fuel.
Al
jA-
Post by jA- »
flyingbrick wrote:glow plugs not working.
your a champ mate it was the big 45amp glowplug breaker was blown...
my bad :oops: :oops: :oops: :oops: :oops: :lol:
cheers guys
