As per title.
Pulled it out today and one rail has broken in half- and then dropped its innards out everywhere... which means I cannot even drive the thing.
If i could buy/borrow one in Hamilton/TA/Waikato area before monday that'd be great.
Thanks,
Nathan.
DRIVERS SIDE SEAT RAILS REQUIRED URGENTLY- WAIKATO
- flyingbrick
Re: DRIVERS SIDE SEAT RAILS REQUIRED URGENTLY- WAIKATO
for a safari?
Yes it is a Safari one. Drivers side inner rail.
- flyingbrick
Oops
Cheers Justin
These trucks must be made for people shorter than myself, ffs. Seat/rail is not really meant to be extended out as far as it is while im driving.
-Nathan
Cheers Justin
-Nathan
Did you get your new seat fitted to the passengers side?
- flyingbrick
Yeah. Fits beautifully- took a bit of fine tuning today to get it right tho. About 5mm clearance on the left hand seat wing from the B pillar, about 5mm clearance between right hand side of seat and center storage box...... and the left hand seat base side bolster is pushed in 2-3mm when you close the door (hits arm rest on door)
its a tight fit!
Had today off work (I don't like the drugs but the drugs like meee) and was hoping to spend a lazy one getting the drivers seat in but then found this farking broken rail.
I'll send that cradle tomorrow eh
I promise. Should be able to drive.
-Nathan
-Nathan
Sweet. I'm off to Greece on Tuesday so will PM a mates address in case you don't manage to send it tomorrow. Cheers.
- skid
- Tyre Man
if you have no joy getting a seat rail
you could probabyl get one from the same place ya picked up ya seats
may cost ya though
may cost ya though
- flyingbrick
skid wrote:if you have no joy getting a seat rail
may cost ya though
Thanks for that BTW!
dont mind paying for a rail. May have to go there.
- flyingbrick
Thanks Rural53 for bringing over that broken one
I ended up popping over to putaru on the way back home- got a rail for $30 from Marie89 (wayne) off Trademe.... Along with a few other bits.
