21st/22nd Nov
worzel
21st/22nd Nov
Post by worzel »
Two weeks in a row come on whats up with everyone
Fixed fuel leak on back of fuel pump what a bitch had to take all injector pipes of to get tool on the plug at the back o ring was rotten fited new plug with o ring all good now took 2 hours to do it then decided to fit snorkel all done
will take tow bar and rear bumper off tomorow fit new freewheel hubs as well
Re: 21st/22nd Nov
its called being busy , ripped the rubber flares off last sat so it time for bunnings flares tomorrow and sliders to make for a challanger
mudmike
Re: 21st/22nd Nov
Post by mudmike »
Put new side bars on during the week, went on club trip today with my 4 year old daughter.
Had a small oopps bent the front bar, going to have to do a rebuild, still it did its job well only small dent in the truck.
Cleary
Re: 21st/22nd Nov
Post by Cleary »
Installed replacement rear seats in the Escudo - after the teens broke one (hmmm now what could they have been up to in the back seat to break it - I wonder...). Tightened the handbrake - still crap - cables not pulling up together - one must be worn/ sticking.
Looked at my E class sammy in the shed - a bit of panel work and cage straightening to do. Need to get on to it, but next round not until end of Jan... :| :| :|
Pedro
Re: 21st/22nd Nov
Post by Pedro »
Cleary wrote: (hmmm now what could they have been up to in the back seat to break it - I wonder...)
have you not got the answer to that already :lol: :lol:
put back diff back together, road tested the locker and works fine, now slips the wheels in turn, tested front locker, it seemed to work fine on axle stands but not at rally, ended up pulling front diff and discover a little issue, sorted that out, broke fitting went inside and watched movies instead, put it back together tomorrow.
then managed to swap some 8" beadlock rims with some 10" beadlock rims, so now have to strip 8 bloody tyres amd change them over onto the new rims after i recenter them with nascar centers. lucky trial is end of Jan.
pedro
Re: 21st/22nd Nov
hes not officially a Grandad yet and already his mind is going
Pico42
Re: 21st/22nd Nov
Post by Pico42 »
Went into Macetown last night - guiding a visitor/novice 4WDer in with their tent-on-trailer.
River up a bit and some of the crossings are a bit deeper - but no real problem as we both have snorkels.
Not so for the Toyota Surf we met at the homestead remains - found it being towed out after ingesting some water.
Seems to be a lot of vehicles hydraulic in there...
Pedro
Re: 21st/22nd Nov
Post by Pedro »
true true, a distant memory perhaps........ :lol: :lol: :lol:
Re: 21st/22nd Nov
faaarking 4wd shite
bloody bits eveywhere
can't find faaark all
bolts don't fit
had grille on and off about 5 faaaarking times already
over this shite for now
its lunchtime
Re: 21st/22nd Nov
doing flares and lunchtime here too :D
safaripete
Re: 21st/22nd Nov
Post by safaripete »
went out
broke shyte
came home
Re: 21st/22nd Nov
as well as 4 flares found front wheel beings not the best rightside loose rumbles , left loose fix it tomorrow
motorhead
Canadian
Re: 21st/22nd Nov
Post by motorhead »
Swapped out an upper a-arm, blead brakes, changed b-joint, changed oil. Waiting to see if new tires in stock :D .
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
Re: 21st/22nd Nov
skid wrote:faaarking 4wd shite
bolts don't fit
its lunchtime
after this little rant, some top blokes turned up and the afternoon progressed a little bit better, albeit with more things to fix along the way :roll: :roll:
cruzerboy
Re: 21st/22nd Nov
Post by cruzerboy »
did this
motorhead
Canadian
Re: 21st/22nd Nov
Post by motorhead »
cruzerboy wrote:did this
:idea: Wall Art
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
allmud
Re: 21st/22nd Nov
Post by allmud »
well got bored took my son ( hes just over 3 ) to supercheep to pick some paint for the zuke
ended up with this lol
and got me these to go on when the wrist is all fixed
just need to find somebody in manawatu to change the offset of the rims and the zuke might not go to sleep on its side as mutch as it usto lol
williamhamilton
Re: 21st/22nd Nov
Post by williamhamilton »
I think there be a story in that!
W
Landcruiser70
Re: 21st/22nd Nov
Post by Landcruiser70 »
Went on a club run up Manawahe. Put the Prado (and the new winch 8) ) thru its paces. The ole runva winch went well for the first run and being completely submerged.
1993 Landcruiser Prado LJ78: 4" lift, Tough Dog sus, 35" BFG muds, ARB air locker, LSD
cruzerboy
Re: 21st/22nd Nov
Post by cruzerboy »
big block 13bt power
Pedro
Re: 21st/22nd Nov
Post by Pedro »
got the front diff back together after making a hydraulic fitting, put front end together and road tested, definitely works now, then got kids motorbike going, fitted disk brake to nieghbours kid gokart, went to skids and spent some more of his money, new bearings, seals and caliper later we are now waiting for parts.
then came home and pulled nieghbours motor bike motor apart, sorted out why it siezed, magneto jammed the flywheel :) put it back together and bench run it,
now i need a weekend to recover :lol:
Pedro
Shane
Re: 21st/22nd Nov
Post by Shane »
half the sliders done,only 50% to go..
allmud
Re: 21st/22nd Nov
Post by allmud »
hay mate is it u selling the wizard on trade me ?
Fakey
Re: 21st/22nd Nov
Post by Fakey »
Looks like exhaust tubing :o
I got most of my new cage built, started saturday morning still got some extra bracing to do an seat an seat belt mounts to do then pull it out to fully weld the bottom parts i couldnt get to
Didn't barbie drive a jeep??
Cleary
Re: 21st/22nd Nov
Post by Cleary »
Pedro wrote:got the front diff back together after making a hydraulic fitting, put front end together and road tested, definitely works now, then got kids motorbike going, fitted disk brake to nieghbours kid gokart, went to skids and spent some more of his money, new bearings, seals and caliper later we are now waiting for parts.
Pedro
How about straightening my cage and bullbar next weekend? :D :D
rotordogg
Re: 21st/22nd Nov
Post by rotordogg »
safaripete wrote:went out
broke shyte
came home
What was it that broke? CV??
At least you didn't kill your truck setting up the obstical's the day before!!
You have yours running by next weekend??
Phil.
It's just more fun in a lada !!
safaripete
Re: 21st/22nd Nov
broke shyte
came home
Phil.
yeah cv shat itself
and because i couldnt turn the wheels the steering slip joint decided to smooth the splines they are now welded :evil:
it should be ready for this weekend but not sure if i want to take it out only to have something else break but will probably go and break more crap :roll: :lol: :lol:
Bulletproof
Re: 21st/22nd Nov
Post by Bulletproof »
See Jafa, Longfields Pete
Cheers Richard
Never say die, up man and try
safaripete
Re: 21st/22nd Nov
Bulletproof wrote:See Jafa, Longfields Pete
Cheers Richard
if i could afford 'em they would already be there :lol:
nuts
Location: somewhere arround westcoast offroading usually
Re: 21st/22nd Nov
Post by nuts »
went up the leatham for a shiney trip :o my eyes were on all the harder bits tho :wink: :wink: then went a bit off track on the way back to westport to look at some future trip :lol: :lol:
cheers flag 4 taking us :wink: :mrgreen:
