Supercustom van engine.
skux
Post by skux »
does any one know if a supercustom van motor will this bolt straight into my ln61 surf?
taz01
Tazzles
Re: Supercustom van engine.
Post by taz01 »
yep bit a changing first ie:oil pickup,sump,engine mounts,to be safe i changed over flywheel clutch etc as well and if yours was turbo you end up with a bundle of unused wiring and no rev counter
WARNING:
nstacey
Post by nstacey »
is the super custom motor an L series or 1kz? L series will bolt in with Taz01's mods
85 Hilux single cab
02 Grand Vitara
skux
Post by skux »
Im not sure on motor numbers, but its out of a 94 supercustom, 3.0td?
would that bolt into my ln61 etc?
sig
Jeep Jeep
Post by sig »
super customs (93ish on) are 1kz
taz01
Tazzles
Post by taz01 »
in that case ignore the above only works in L series
WARNING:
skux
Post by skux »
Ok Thanks ANyway mate, Does any one have any info on putting this 1kz in my ln61?
BFTP
Post by BFTP »
its too hard i wouldnt bother. By what i hear u need to cut and weld mounts n the chassis, wiring is completely different, etc etc. If u can find a 3l or 5l thats not much modification and theyr not far off in power to the 1kz
tweake
Post by tweake »
skux wrote:Ok Thanks ANyway mate, Does any one have any info on putting this 1kz in my ln61?
anything is possible.....its just time and $$$ ;)
have a look on http://www.toyotasurf.asn.au/forum/
they have a few who have done the conversion on LN130's. not sure with the LN61, a few things may be different especially gearbox wise.
a 3L or 5L conversion would be easier as there is no ECU to wire up.
skux
Post by skux »
Ok, im tryn to get hold of a 5L now.i just sold the super custom engine. What do i find a 5L in so i can inqiure on TM?
Swaney
Post by Swaney »
I have a 3L in my 84 lux (non turbo 2.8L) its not exactly a speed demon but still (just) manages to pull my caravan around the country (at 95km with a tail wind and 30-40km up hill)...
Its loads gruntier than the 2L though...
Now thinking about putting a V6 holden in just need to convince the mrs its "money well spent" lol - that seems to be a common swap if your looking for a decent amount of power
nstacey
Post by nstacey »
skux wrote:Ok, im tryn to get hold of a 5L now.i just sold the super custom engine. What do i find a 5L in so i can inqiure on TM?
NA Hiace newer than about 98? Hilux 98 to 2001 or so, newer than 2001 Hilux has the 5LE which has an electronic diesel injection pump which will be more complicated to set up.
85 Hilux single cab
02 Grand Vitara
