replacement fairlead rollers for PTO winch
Posted: Mon Nov 23, 2009 4:32 pm
by williamhamilton
Hi, where would I get some replacement rollers for a Toyota PTO Winch?
W
Re: replacement fairlead rollers for PTO winch
Posted: Mon Nov 23, 2009 4:54 pm
by coxsy
for my safari i cut the old fairlead off and welded another new complete unit on had to change the pins and circlips for bolts and nylocks
Posted: Tue Nov 24, 2009 10:44 am
by williamhamilton
coxsy wrote:for my safari i cut the old fairlead off and welded another new complete unit on had to change the pins and circlips for bolts and nylocks
Thanks Cosxy, I see some cheapy ones on TradeMe. Anything to watch out for?
W
Posted: Tue Nov 24, 2009 11:52 am
by mudmike
Watch the ones with plastic bushes, they deform and bust under load, also the pins are only held in by clips, is worth changing to sealed bearings and bolts.
Posted: Tue Nov 24, 2009 3:10 pm
by albundy
Some of them are also made out of thin steel, not thick and they go out of shape wehn the load is transferred through the rollers to steel frame.
Al
Posted: Tue Nov 24, 2009 3:12 pm
by coxsy
yep you guys got all the problems listed with after market ones. so what they say is right
