I see its only rated to just over 3ton-
1,what usually fails when exceeding rating? The shear pin/housings/shafts
and 2, what breaks if you use a larger diameter shear pin to raise the pull a little.
3, any ways of making it stronger? reinforced housings etc?
4, Do they have a brake and is it inside the drum? Synthetic is OK? What happens if the shear pin snaps- does the line instantly go slack or does the brake hold things until somehow released?
5, any info on rebuilding?
Chur
