trial fitted slider's on the challanger
safaripete wrote:fitted the power steering pump today and plumbed it up
but for some reason it still feels way heavy
suzuki1k wrote:Pulled the gearbox out of mudnutz bush truck to replace the clutch, got there and it was raining but he has a great garage and we kept dry. Decovered that the gearbox mount was broken and the flywheel needs some attention, so it's all in parts.
That makes three trucks that I am now working and they are all in parts... you think there is a pattern here![]()
haynzy wrote:safaripete wrote:fitted the power steering pump today and plumbed it up
ya gotta bleed it properly
safaripete wrote:haynzy wrote:safaripete wrote:fitted the power steering pump today and plumbed it up
yeah did that.
full lock to full lock
DieselBoy wrote:Fixed some peeling clear coat and hacked of the rear quarter panels on Toyoda's rig![]()
Heath wrote:suzuki1k wrote:Pulled the gearbox out of mudnutz bush truck to replace the clutch, got there and it was raining but he has a great garage and we kept dry. Decovered that the gearbox mount was broken and the flywheel needs some attention, so it's all in parts.
Yep. KEEP THIS MAN AWAY FROM YOUR VEHICLE!!!!![]()
Just kidding, shows character and a willingness to help others..
albundy wrote:Turned a set of Auto-lock Nissan hubs into free-lock hubs. Works a treat and front diff with lokka is more happy for it![]()
Al
sig wrote:you can adjust the falcon boxs there is a lock nut on a screw on the top (under a cover from memory ) that will help with free play (10 beers now)
safaripete wrote:sig wrote:you can adjust the falcon boxs there is a lock nut on a screw on the top (under a cover from memory ) that will help with free play (10 beers now)
haha yeah which way tightens it up??
