80 series oil pressure ??
Posted: Sun Nov 29, 2009 7:18 pm
by skid
I'm curious to know what oil pressure other 80 series owners are running
mine is a 12 valve and as you can see from the pic, its low
this was in 4th gear at 1600rpm................
Re: 80 series oil pressure ??
Posted: Sun Nov 29, 2009 8:06 pm
by Andrew1706
Mine does that, from my investigations on the net it's due to a combination of the sender on the block or the guage in the dash.
Posted: Sun Nov 29, 2009 8:17 pm
by badnuz
you did your BE bearings when rebuilding aye?
like Andrew says, i fitted a VDo as well as the factory unit and the VDO reads much higher :) i also fitted a VDO temp gauge and it goes from 80 to 95 but the factory temp gauge stays put... for the extra couple of hundy on top of my rebuild its great piece of mind to accurately monitor the engine :)
Posted: Sun Nov 29, 2009 8:27 pm
by Jerry
My old LJ71 did the same thing just after an oil change, the filter was changed again (in case it was a dud) and the guage was checked. it came right a bit afterwards.....
Its not a problem with the wiring or something?, have you looked at the fuses after it was sunk? maybe its a bit of corrusion on the fuses etc?
Posted: Sun Nov 29, 2009 8:46 pm
by DieselBoy
Fark, I thought everyone knew that the first thing you do when you get a Toyota of any sort is put in a mechnical temperature gauge and a mechanical oil pressue gauge.
The factory electrpnic oil pressure gauges don't last long, the sender units clog up with oil sludge and stop reading correctly.
Go to repco and buy a $12 mechanical gauge and plumb that in. Half an hour job, and then you know exactly whats goin on :D :D
Posted: Sun Nov 29, 2009 8:59 pm
by UBZ
badnuz wrote: i also fitted a VDO temp gauge and it goes from 80 to 95 but the factory temp gauge stays put...
Toyota factory temp gauges have a factory flat spot built in.
Designed to reduce service calls about fluctuating temp gauges. :roll: :roll:
When they go into the red, its sudden and its to late!the damage is all ready done generally.
Posted: Mon Nov 30, 2009 6:18 am
by Jacko
4th gear, 1600rpm...
after reading the above comments i think i'll look at fitting mechanical gauges at some stage....
Posted: Mon Nov 30, 2009 7:21 am
by skid
even though the pic was taken yesterday
I just thought I'd point out, that the gauge was reading the same before the engine rebuild as well
cheers guys
even though you are all saying to go buy mechanical oil pressure gauge
can they be trusted ??
the ol 40 had these and the water temp one was reading wrong, it would always read 30 degrees higher than the highest digital temp we could get off the motor
or maybe we can't trust the flash digital thermometer :roll:
aaaaaargh wot to trust :lol: :lol: :lol: :lol:
Posted: Mon Nov 30, 2009 8:37 am
by UBZ
I run both the factory gauges and aftermarket ones.
and modded the Toyota Temp gauge to remove the flat spot.
Two sets of gauge has to be better than one :mrgreen:
Posted: Mon Nov 30, 2009 11:29 am
by pruggerdore
Mate of mine spent 10 grand rebuilding his engine. apparently the oil gauge still sits in the same place too. He not impressed. guess I should tell him to do the gauge.
Posted: Mon Nov 30, 2009 5:45 pm
by DieselBoy
pruggerdore wrote:Mate of mine spent 10 grand rebuilding his engine. apparently the oil gauge still sits in the same place too. He not impressed. guess I should tell him to do the gauge.
eeeeeeweeeeeeyup :D :D
Posted: Mon Nov 30, 2009 6:45 pm
by Bulletproof
I personally like the electric gauges as long as they are a good brand.
I use the VDO ones that are used on ships and planes.
They are very sensitive and the advantage of electric for 4 wheel driving is an oil pipe can't break on the track with a loss of pressure that can happen with a mechanical one.
This is only my preference from using both.
Cheers Richard
Posted: Mon Nov 30, 2009 7:02 pm
by skid
Bulletproof wrote:I personally like the electric gauges as long as they are a good brand.
Cheers Richard
sounds like good advice Richard, but as I already have a electrical gauge, I think I will go get a mechanical one to accompany it and see if it reads any differently for me
churr churr
