Hi all
probably been asked before (i couldn't find any posts on this)
as the subject line how do you tell the differance between the 8 valve and 16 valve 1600cc motor?
any advatages either way plus should i be looking for efi or cabi.
wondering as to what i should be looking out for in a early to mid 5dr escudo or vitara
thanks for the comments both negative and positive
how to tell 8 valve or 16 valve
Re: how to tell 8 valve or 16 valve
Well I have a 8V carb motor and it seems to have more torque than the 16 valve, but the 16v have more power and use less fuel.
as to how to tell i will get back to you as I am drawing a blank for some reason. I used to know. Most 16V have it on the back door, usually like JLX 16 VALVE. if is a vitara.
I would go with 16V motor for the LWB model though.
Lincoln
Lincoln
Ok cant work out the url things at the moment.
This is what you ould see if Injected
http://auto.vl.ru/images/2931/3211/2104.jpg
and this for carb
and this for carb
cool thanks guys
8 valve has a blank rocker cover with sparkplugs fitted with normal leads (as in the lower picture) and 16v has 16 valve on the cover and has the long ceramic plug covers. I think.
I dont think 16v ever came out TBI or carb.
- Rotazuk
To make life real easy for you the 5dr only came with 16v
Chris
Chris
Rotazuk wrote:To make life real easy for you the 5dr only came with 16v![]()
Chris
That makes things real easy thanks
Go the 16V!!!
I put one in my sammy and they just sing
Get your foot up it and make that rev limiter work... Seriously - they love to rev
i got a SWB 16V on Xmas day (not as a pressy lol) but to use at Woodhill on week ends and have fitted performance cams, jeepers does that girl go............
