Any suggestions would be welcome, might have to do master cylinder next, trying to avoid as running low on funds!
MudBum wrote:Was the new piston put in the right hand side??
Put new ones in mine awhile ago and the pistons were not an exceptional fit and caused sticking,an engineer took a smidge off an no probs since.
flyingbrick wrote:Lets apply some logical thinking that a few others have missed.
Truck pulls to the right... which means that the right side of the car is braking MORE than the other side.
Which means that if there is a sticking piston (caliper sticking open) it will be in the left hand side of the truck.
flyingbrick wrote:-Are both front tires the same? Is one a directional on backwards? One more worn than the other? Its hugely noticeable.
-Change all the bushes IMO so they are even both sides
-Get your shocks tested by someone who knows how to test them
-AFAIK brake systems are completely linked left and right (though im no expert) so feel that ANY air in the system would have the same effect on each side regardless of where the air is.
-degrease your disks and pads (or get new pads if they are a little worn- wont hurt) its possible all this leaking has made the disk greasy.
suzuki1k wrote:Where are you in the country? May be albe to pop round if you are close and assist...
