5th and 6th dec
5th and 6th dec
mine again :) had the challanger around from 9.30 till 2 pm set up the sliders on the truck tack welded , take them in to work to mig up, all done :D
nstacey
Re: 5th and 6th dec
Post by nstacey »
Getting pissed off with settting up the powersteering reservoir on my hilux. Because my radiator is for manual steer have had a pipe made up to go behind the steering pump. but this is now stopping me tensioning the powersteering belt as the hose that goes to the reservoir interferes. Done for the day will look at getting some more powersteering hose tomorrow.
85 Hilux single cab
02 Grand Vitara
tallsam66
Re: 5th and 6th dec
Post by tallsam66 »
Finally got most of the work done on the hilux
Wheels & tyres
new rear bar
Sliders.
Almost all ready to get muddy
wopass
Re: 5th and 6th dec
Post by wopass »
dropped my son into his race seat in the 40 and went for a blaze up thomos...
was a bloody nice day really :mrgreen:
Re: 5th and 6th dec
nice one wopass, how was the track
niblik
Re: 5th and 6th dec
Post by niblik »
wopass wrote:dropped my son into his race seat in the 40 and went for a blaze up thomos...
churr...... 8)
wopass
Re: 5th and 6th dec
Post by wopass »
wouldnt want to do it in a shiny on road tyres, bit cut up now with some interesting stuff at the clay climb half way up ish, met a dude and his missuz in a black safari on the way up who followed me and had no worries.
Andrew1706
Re: 5th and 6th dec
Post by Andrew1706 »
Race seat and goggles are just too cute :oops: :oops: :oops: :mrgreen:
wopass
Re: 5th and 6th dec
Post by wopass »
Andrew1706 wrote:Race seat and goggles are just too cute :oops: :oops: :oops: :mrgreen:
yea its pretty cute, cool as when hes got the full race harness over the top of the kiddy seat harness and hes laughing his head off at stuff most people would be scared of :shock:
like going up the hard side of the summit track cos "theres more mud in it" so as any driver does i did what my navi told me to do :lol:
Landcruiser70
Re: 5th and 6th dec
Post by Landcruiser70 »
Yea, thought Cam must've been getting a bit to old for winch challenges. :P
As for me, went for a play up Pete Flemmings farm last night and lost my corner bar so went up this arvo to get it.
1993 Landcruiser Prado LJ78: 4" lift, Tough Dog sus, 35" BFG muds, ARB air locker, LSD
motorhead
Canadian
Re: 5th and 6th dec
Post by motorhead »
Replaced a-arm(thx Bolo), flipped BJ's and twisted torsion bars up a bit just enough to keep it with just a slight nose down stance. Pulled running boards, looks like a 4X4 not a family cruzer.
Will be putting SWB Safari springs in rear(thx Malfunction) over Christmas and then twisting front up to level.
Testing at Ocean Beach on Sun :D :D :D
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
nstacey
Re: 5th and 6th dec
Post by nstacey »
Got Set to drive the hilux to the end of the drive and back. But now have clutch woes. Can only engage forward gears when motor is running, it will not go into reverse. The clutch engageswith the slightest movement of the pedal from the floor, have bled the clutch system twice. We think it needs a larger thrust bearing. There was a few to choose from for the L series motors when I bought the clutch kit. Which sucks because I don't want to have to drop the gearbox again.
85 Hilux single cab
02 Grand Vitara
Re: 5th and 6th dec
nstacey wrote:Got Set to drive the hilux to the end of the drive and back. But now have clutch woes. Can only engage forward gears when motor is running, it will not go into reverse. The clutch engageswith the slightest movement of the pedal from the floor, have bled the clutch system twice. We think it needs a larger thrust bearing. There was a few to choose from for the L series motors when I bought the clutch kit. Which sucks because I don't want to have to drop the gearbox again.
There should be some adjustment somewhere, the pushrod or the ball the clutch fork pivits on should both be able to be wound out a bit with the gearbox still in place :mrgreen:
Re: 5th and 6th dec
no marty get him to pull the box again to find out he don't need too , helps him learn about toy motors :twisted: :twisted:
nstacey
Re: 5th and 6th dec
Post by nstacey »
Cheers Marty. but have just had a look, there is no adjustment in the pushrod and if I unwind the pivot point in the bellhousing (looking at my old one) I'm fairly certain it'll rattle loose as there is nothing to tighten it on to.
85 Hilux single cab
02 Grand Vitara
Landy Rover
Re: 5th and 6th dec
Post by Landy Rover »
Try making a longer pushrod by 5-10mm. Use a long 6mm bolt cut to length and round ends on grinder.
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
Dr_PC
Re: 5th and 6th dec
Post by Dr_PC »
Spent quality time with my wife checking the roads and directions for the Fun Rally next weekend, if you are coming you may want to check them
http://www.offroadexpress.co.nz/Forums/ ... 64#p217364
meece4x4
Re: 5th and 6th dec
Post by meece4x4 »
Attended the Annual Whangarei A&P Summer show with the Whangarei 4wd club this weekend, first time at this advent, had a ball and a really good event to iron out any kinks/issues with the Mistress, only had one small issue and that is the electric fan isnt pulling enough airflow through the radiator, and in the hot hot conditions she was running a little hotter than i would have liked, not overheating just a few mm up the temp gauge higher than normal.
this event is pretty hard on trucks at the best of times ... two whole days sitting on the rev limiter and pushing the trucks faster and harder than normal to apeeze Joe public's vision of a 4wd.
lots of trucks on Sat .. not so many on sunday .. lots of breakages on Sunday! the Geen Zook had a electrical fault that killed it halfway though the bog :(
Happy to say the Zook made it though the weekend without breaking anything ... important anyway :) The red Zook broke a CV on Sat .. got that sorted then suffered from overheating issues, got that sorted as well then next run around sheared the front diff mounts launching out of the bowl. game over after that one
Hopefully I will regain hearing in my left ear soon *teenage girls can scream loud cant they!!*
no comment
HBpajero
Re: 5th and 6th dec
Post by HBpajero »
A few of us from Hawkes Bay (22 or so) went out and moved middle earth so we could go 4wdriving :lol: :lol: :lol:
how 8) is that :lol: :lol:
J_Dub
Re: 5th and 6th dec
Post by J_Dub »
brought a little boat
looking now for a 20-30hp outboard
suzookyman
Re: 5th and 6th dec
Post by suzookyman »
spent sat with meece4x4 and the rest of our club at the whangarei summer show,broke nothing (last year smashed front diff) so rather than risk going out again on the Sunday went for a freedive and cleaned the zook when i got home...........man i love livin in the north, our coast is primo 8) 8) !
flyingbrick
Re: 5th and 6th dec
Post by flyingbrick »
I spent the day at car tune working on vvega's new hilux cab. Cab has frontal impact damage and so there were alot of spot welds to drill out.
I also cut the fcuk out of his donor surf with a plasma cutter. First time using one- its the best tool ive ever used im sure. 8) 8) 8) 8) 8) Beats the dick out of sabre saws!
-Nathan
nuts
Location: somewhere arround westcoast offroading usually
Re: 5th and 6th dec
Post by nuts »
got a wof on me truck finnished off rocksliders,lifted spare wheel carrier up to accomidate larger tires,now need to do an oil change lol never ending :lol: :lol:
Smurf
Re: 5th and 6th dec
Post by Smurf »
nuts wrote:got a wof on me truck finnished off rocksliders,lifted spare wheel carrier up to accomidate larger tires,now need to do an oil change lol never ending :lol: :lol:
Did Nuts get some flash new feet for his Nissan?
Re: 5th and 6th dec
watched my daughter in her first xmas parade yesterday
then threw some shite in the cruiser and took it for a run over the rimutakas so daughter could decorate xmas tree with granny
impressed with rebuilt motor in cruiser, pulled 5th gear all the way up the Kaitoke hill and 4th gear most of the way up the rimutakas, sweeeeet
had lots of nanna naps over the weekend, coz the parents house has comfy couches in bloody sunny spots and as if I didnt get enought rest, I'm off to bed now
:lol: :lol: :lol: :lol: :lol:
badnuz
Re: 5th and 6th dec
Post by badnuz »
zoomed up to Costa to cut in some new tracks for the Tuff Truck :twisted: even got the 80s wheels dirty :)
SirGerald
Re: 5th and 6th dec
Post by SirGerald »
Got about 1/2 way up takapari and truck started coughing and farting. Decided better to turn around and head back while all down hill just in case something major went wrong.
Parked truck back in shed and will look at what wrong another day. Hopefully just something wrong with leads or spark plugs.
Team Lada Loves Sloppy Holes!!!!!!!!!!!!!!!
rotordogg
Re: 5th and 6th dec
Post by rotordogg »
SirGerald wrote:Got about 1/2 way up takapari and truck started coughing and farting. Decided better to turn around and head back while all down hill just in case something major went wrong.
Out of the 7 truck's that started, only the 4 shiney's made it to the top!! Lesson: leave shiney run's for the shiney's!! :lol:
I cracked the top tank in the radiator 100m before SirGerald turned round!
It's just more fun in a lada !!
nuts
Re: 5th and 6th dec
Post by nuts »
nope just couldnt fit them on wit bar work so lifted carrier
Swamped
Re: 5th and 6th dec
Post by Swamped »
Pulled a V8 and gbox out of a commer van. Cheers to escudoboy for helping out.
Camera died after these were taken. Had to cut a hole in the roof to use chain block for final lift :lol:
