just wondering if any one can help me even wreckers are haveing troube finding me this part but here goes
i need a rear complete axle-drum brake set up for drivers side of a nissan navara 4x4 2.7 factory turbo auto jap import now i think the main trouble is most nivaras have a <SAWSBURY DIFF>unbolts from rear where my diff is like all terranos unbolts from the front desparately need truck up and running asap.
if any one has advice or can help me that will de great
on the drum it says max diametre of 298.5mm
issues finding rear axle for 93 nissan nivara
- mushroom11
- Bush Crasher
Re: issues finding rear axle for 93 nissan nivara
Can you not use the rear off a Terrano instead?
Ph 0212078472
Ph 0212078472
what part of the country as guy in chch wrecking 2 navaras on trade me
his cell 0211756479
his cell 0211756479
- mushroom11
- Bush Crasher
im in gisborne mate the issue is mine is a jap import.nz navaras just came out 2.7 and all have salsbury diffs cant use those axles and drum set up cause of diffrent axle spline count.
pathfinder/terrano or mistral diff ?
can you find a code for the diff ?
it sounds like you may have the h233b diff which was also used win some D22's.
a mate has a 2.7 turbo D21 so i can check.
