Ive seen on Trademe 2 diff sizes 12mm & 16mm....mine is drilled for 22mm.
Receiver Hitch Pin Size
What size is standard for a Receiver Hitch Pin
Re: Receiver Hitch Pin Size
mine is 16mm, I think the warn recovery insert is for 16mm pin also
tallsam66 wrote:What size is standard for a Receiver Hitch Pin
Ive seen on Trademe 2 diff sizes 12mm & 16mm....mine is drilled for 20mm.
Down to your local farm supply store and get a 20mm pin
Tallsam, yours is drilled for 20mm as you wanted to "possibly" snatch off it
- malfunction
I use a 20mm too but never seen that size on tard me, best to just cough up the bucks and buy one from where you got the tow bar so you know its quality!
Mal
021 0666826
021 0666826
I found some Hilti 20mm grade 8.8 bolts & cut them down & drilled a hole in it.
Brought some clips from bunnings so now have 4 pins for a total cost of about $6
