Im after a 7 rib cressida 5mge alternator and a rear surf or hilux driveshaft dont care to much about condition of the driveshaft can anyone help?
Thanks Stu
5mge alternator and hilux rear driveshaft wanted
Re: 5mge alternator and hilux rear driveshaft wanted
Where abouts are you?
- rangimotors
I have a few different ones 4 or 5 in total i think, I have 2/3 the same which fit my engine and 2 different ones which don't I think one sort is 5m and the other is 6m, I want to keep the ones for my truck but if you want the others then im sure we can sort something out. Can you post a picture of the one you need, including the plug at the rear, I think one is round and the other is a square or L shape from memory.
Hi it has the round three pin plug and the mount instead of being two small lobes with a hole through each, its one big lobe with hole through ill try and get a photo of it.
Thanks Stu
Thanks Stu
- rangimotors
ok no problem i cant remember which ones I use and which ones i have spare so ill check tonight, from what i'm told the insides are pretty much all the same and you can swap the housings around without to much drama so that could be an option as well.
