Hi pinion front diffs
Okay boys, tell me what years, models, and ratios etc landcruisers have high pinion front diffs?
Will they fit the standard hilux housing,
I'm after a 4.88 High Pinion for my junk, I think out of a 80 series?
Cheers for any info
Cheers for any info
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
prados aswell, but as jungle said 4.1s are the most commons for the simple reason most of them are driven by diesels
,but you can get 4.88 ring and pinion kits............
but why you goin hp?have you a mega lift?or you using a prado housing with the reversed idler arm.......
just curious jafa thats all
krawlr wrote:but why you goin hp?have you a mega lift?or you using a prado housing with the reversed idler arm.......
Not a mega lift, 100mm, but teh HP helps with driveline angles
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
http://www.outerlimits4x4.com/PHP_Modul ... hp?t=69662
This may be of some use.
L/C from 91 on including Prado's 93 on have the larger CVs and run the 8"diffs
hmm that link dosent say anything regarding cv sizes (or i may of mis-read)
any body got any pics of the different sizes?
4wdnuts/i wonder if those part numbers are regarding the size difference just because in the early 90s they fitted a ring gear to the outter bell for the speed sensor to run on for the abs system
pics,pics ,pics.............
Off-topic police alert :rambo:
Start a new thread for new topics guys, Multiple topic threads make it hard to find information 12 months down the track when people are looking for it.
Steve
SupraLux wrote:HILUX axle with 4.88 high pinion front fitted... direct bolt-in replacement for the standard 8" diff.
The 2.4TD Prados ran a 4.88 high pinion front...
Steve
Thats exactly what I'm after....now do you have one to sell, or know of one
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Yep, you can have mine... $12,000... comes with a MU
Other than that, no... I had to search high and low (pinion
) to find that one... it was a lucky score when I got it... and I had to have it shipped down from up north somewhere...
Keep an eye on trademe, as there was a guy wrecking a 2.4 prado on there a while back... palmy nth or thereabouts from memory...
Steve
Steve
