vr v6 surf(problems)
86-surf
Post by 86-surf »
ok my vr v6 surf is making popping noises wen idling and at higher(3000rpm'ish) makes a kind of pinging noise. its quite loud and sounds like a big exhaust leak, iv checked and havn't found one, it also happens wen under load at lower rpm, it was doing the same thing on the old vn engine that was in it about 3 weeks ago.
the oil pressure gauge reads prity low. its got oil and the oil pressures been the same since iv owned the truck, i did a oil/filter change wen i put the new engine in.
any advice or info would be great thanks.
jase
Petemcc
Re: vr v6 surf(problems)
Post by Petemcc »
probably a stupid question but are all the leads on the right way sounds to me like a couple could be backwards
86-surf
Post by 86-surf »
ok i may be blonde but im not stupid lol.
they are on the right way
Steve_t647
Post by Steve_t647 »
He means correct firing order. It does sound like it could be a misfire. Did you use the same coil packs on both engines?
The only other thing that could be common to both engines is the fuel system but I have no idea how it would cause your symptoms.
Start the car and pull the plug leads seeing if you get a missfire, if you pull a lead and nothing happens check the lead, coil, plug and then the injector if they all check out.
86-surf
Post by 86-surf »
i pulled all the injector plugs off and there all sweet. starts missing every time i pull a plug off.
I'm prity sure all leads are on right, and the spark plugs are relatively new.
thanx
wopass
Post by wopass »
put a fuel pressure reg on it and get the injectors serviced.
excess fuel goin in, fuel in zaust popping is that fuel burning, quite a common thing with commys when big zausts are put on and lack of mufflers, not noticable when going thru standard zausts.
just a guess tho :wink:
86-surf
Post by 86-surf »
thanks wopass,
i read somewhere the the ngk spark plugs for these are sh!t, so im going to go buy some new ones..
UBZ
Post by UBZ »
we want pic's of said Surf :wink:
you brought another truck, jase and didn't share :cry:
Landy Rover
Post by Landy Rover »
Nothing wrong with NGKs. Do you run oxygen sensors? Could be faulty. Need to do fuel presure and flow test. What parts have you retained from previous engine? If itwas doing the exact same as is now look at what components you have reused. Make very sure there is no air leaks down stream of MAF sensor, vacum hoses, even valley. On a side note check tightness of valley nuts, they become loose and suck in water down the back of head into the rear cylinder inlet port, left hand bank seams to suffer the most. Hope some of that helps.
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
86-surf
Post by 86-surf »
cheers landy. it also seems to puff a light mist out the exhaust. i fought it was just over fueling.. the onlythings i used from the previouse engine are E'manifolds sump, coils, powersteer, pump, alti, etc etc.
how do i do fuel pressure and flow tests??
and i haven't been on the site in donkeys years, and just moved out of home, and have a fulltime job and one day off a week. so finding it very hard to find time to do things.
will upload pictures wen i can find the camera.
gimmemud
Post by gimmemud »
If you have reused the coils that would be the first thing i'd check. I always carry at least one as a spare cause i've heard they can be a bit iffy
Landy Rover
Yes definitely check coils, might want to take then into a garage or auto sparky to do, also need a proper fuel presure tester that gets put in the line from pump, also checks presure reg as well, again may need to see a garage with the correct gar to do it.
86-surf
Post by 86-surf »
cheers guys. will look into it.
another question, how to i raise my oilpressure.....?
Landy Rover
Thicker oil or engine rebuild :( Low oil presure normally means larger bearing clearances or just getting worn out :(
wopass
Post by wopass »
Landy Rover wrote:Thicker oil or engine rebuild :( Low oil presure normally means larger bearing clearances or just getting worn out :(
or the gauge/sender unit is shot. get a new mechanical oil pressure gauge set up from ripco and get that on then see what you pressure is.
and yea get your coils checked
86-surf
Post by 86-surf »
oh wonder full. more money to spend on the bloody pos. ohwell i geuss you have to spend money . .
ill go with the mechanical oil pressure set.
the ticking noise is now ticking on idle... i tried to take a video on my phone and a voise recorder but did not work.. all you can hear is the engine .
86-surf
Post by 86-surf »
Landy Rover wrote: valley. On a side note check tightness of valley nuts, they become loose and suck in water down the back of head into the rear cylinder inlet port, left hand bank seams to suffer the most. Hope some of that helps.
where are the valley nuts?. just got a mate to rev the truck wile i had my hand over the exhaust and there is water coming out.
Landy Rover
Take the cover off and down each side of the inlet valley is the bolts or nuts that screw it onto the cylinder head
Steve_t647
Sounds like a head gasket, water can also cause a missfire. If you are going to pull the sump to check the oil pickup check the main bearings these could be part of the oil pressure issue.
You should be able to find someone with a mechanical oil pressure gauge, all you need to do is prove the accuracy of the current sender :)
Oil is very important in these engines especially on angles :)
Landy Rover
Steve_t647 wrote:Sounds like a head gasket, water can also cause a missfire. If you are going to pull the sump to check the oil pickup check the main bearings these could be part of the oil pressure issue.
Yeah, ask Mudnuts :(
86-surf
Post by 86-surf »
lol cheers guys. will price up the head gasket set.
herd they are cheap as chips. and ill make it a weekend project for myself. .
i cant take the sump off, i need to take the engine out to do that :roll:
thanks again
wopass
Post by wopass »
water comming out the zaust could be just condensation, if its not loosing any from the radiator over a period of time then theres no worries there.
