Best leaf springs for rugger....
Please could someone in the know, tell me the best springs i can use in my 92 rugger f75v. My fronts are buggerd so need to replace with a low budget please help thank you all. Garb0
Re: Best leaf springs for rugger....
get them reset. most others will put your wheels in the wrong place and you will have to do a lot of work you prob dont want to do
thx m8 a nice straight answer.
yep get them reset or take the old ones into a suspension outfit tell them what you want and give them 1 to look at and take the needed measurements off.
i used hilux rear springs on my build and it was a head ache to do had to cut guards majorly and lengthen brake lines put the fuel tank in the back and make new rear drive shaft, and still need to make wedges to ling the front diff up properly
cameronmaxwell@xtra.co.nz
0274202727
0274202727
reset. easiest by far
i have a couple of sets free to a good home. pick up in dunedin though
- niblik
- Sausage Shack
callum007 wrote:i have a couple of sets free to a good home. pick up in dunedin though
that sounds the best option to me!
