TJ rear axle: Play
Posted: Tue Dec 22, 2009 11:34 am
Hi team,
In my wisdom and right before Xmas I thought I would rebuild the rear brake drum setup on the TJ for Xmas. I removed all the bits and bobs and have located replacements for the broken parts etc, no problem. While I was cleaning everything out I noticed about 5mm play in the drivers side rear axle. This play is movement in/out of the diff. There appears to be about half that on the passenger side.
Rather than stripping everything down has anyone come across this or might have an idea what needs replacing or adjusting etc.
Rod
Rod
