Prado or Surf with 1KZ
wjw
Post by wjw »
Anyone know if the fuse marked ECD should have 12v when the ignition is off?
Bill
Who knew Prados could fly?
UBZ
Re: Prado or Surf with 1KZ
Post by UBZ »
my 1KZ-TE manual shows the ECD 15A fuse directly connected to the battery for both Hilux and Prado
White wire going to battery , Red/Black Wire going to ECD Relay and ECU
wjw
Post by wjw »
Bugger, it's drawing a constant 0.8 Amps and I can't figure out why, was thinking I should just move it to ignition, can you measure yours and see what its drawing?
IcedJohnno
Trailer Trash
Post by IcedJohnno »
Do you want to run a meter over mine Bill?
No point in me doing it
WHERE THERE IS SMOKE, THERE'S WIRES I SAY!
Am only 10 mins from your work.
UBZ
Post by UBZ »
0.11A draw with ignition off :(
0.08A with ECD Relay removed.
0.01A with ECU disconnected.
So ECU drawing 0.07A approx with ignition off.
Measured with a good fluke meter. 95 1KZ-TE Surf. Prado / later model intercooled 1KZ-TE ECU figures may be different.
Only 3 possibility as i see it , ECD relay , ECU or a short to ground in the loom.
wjw
Post by wjw »
Yea thats what I thought. Something wrong somewhere. Thanks for that.... will have to do some more hunting.... :-(
UBZ
Post by UBZ »
Good luck
yell out if you need any electrical drawings
Chris
