Hi
Have bent the bottom arm on the window regulator (passenger side) and wonder if anyone has one that they can part with??
The window regulator is the arm that goes up and down like an expanding x when you turn the window handle to push the glass up and down.
Can manually pull the window up and down but it doesn't shut completly and is a hassle as before you can stop them the passenger winds it down and then hard to get it up again (gee perhaps time for a pill)
Stu
SJ413 / Samurai Window Regulator Required
Team Lada Loves Sloppy Holes!!!!!!!!!!!!!!!
