Not starting***FIXED***
motorhead
Canadian
Post by motorhead »
Wagon was working great never an issue starting but now will not crank.
Headlights strong, conections good, fuses and fusable links good, relays all clicking away just no starter action. Have parts truck, will swap out starter but I don't think that's the problem :evil:
Am I missing something? Any help would be great :!:
Out work'n on it :x
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
MikeL200
Gadget Guy
Re: Not starting
Post by MikeL200 »
Give the starter a light tap with a hammer.
Possibly the connection is a bit loose, I have that trouble with my L200.
Mike
1989 LandCruiser MWD BJ74 13BT
33 Deserthawk XMT.
If guns kill people, then,
Spoons make people fat,
Pencils mis-spell words,
and Cars make people drive drunk.
021 666812
Pajmad
Re: Not starting
Post by Pajmad »
Try the start relay located by the battery box they fail
1992 lwb Pajero 2.3tdi 15psi Keeping It Real
motorhead
Canadian
Re: Not starting***FIXED***
Post by motorhead »
Smacked it around with a long pipe, no room to swing a hammer. Tried to start it and it gave a little grunt but that was all, so it was the starter afterall. :oops: :oops:
Went to pull replacement from parts truck to learn how to get at the bolts...holy carp, it's tight up there. Swaped starters and away she went. :D :D
Thanks for help'n me give a big pop and pull my head out :oops: it was just basic trouble shoot'n.
Cheers, Paul
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
The old starter may be able to be fixed cheaply, they have bushes in them which can be replaced. Get it fixed up as a spare....
MikeL200
Gadget Guy
Post by MikeL200 »
Take the stuffed one to auto-sparky, I took mine to Bill Blackwell in Upper Hutt, sorted problem pretty quick.....glazing had built up on commutator.
Give the power in tab a twist so it makes a firm connection, stops it vibrating loose.
Mike
33 Deserthawk XMT.
021 666812
motorhead
Canadian
Post by motorhead »
This might explain the starter grinding on occasion, gear not totally engaging. Is the gear reversable, if not might need a new one.
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
MikeL200
Gadget Guy
Post by MikeL200 »
Bill sorts them out pretty good, mine sounded very different when he finished with it, just over $100 all up I think. He stripped, cleaned, and used some magic, no problems with it now.
As for the grinding, there may be something caught inside, or the glazing has bulit up.
Mike
33 Deserthawk XMT.
021 666812
Return to “Mitsubishi”
