muffler talk
Posted: Tue Dec 29, 2009 10:35 pm
by new2zukes
well will be needing to make up an exhaust for my truck soon, its a toyota 3y motor, its going to be 2.5inch with muffler. a few questions on mufflers though if i were to say get a skyline muffler and then find another muffler of a similar size would they sound the same? or could they be differant and do mufflers act like a fire arrestar or whatever they are called, to lower the chance of sparks coming from exhaust. i have a coby muffler on my 1300 zuke motor and its as noisy as it was without a muffler so i presume that was just a fire arrester. i also presume the bigger the muffler the quieter the exhaust. any help answering some of the questions would be much apreciated.
thanks.
martin
Re: muffler talk
Posted: Tue Dec 29, 2009 11:17 pm
by motorhead
Try turning colby backwards, it should increase back pressure very slightly and make it a little quiter.
Re: muffler talk
Posted: Tue Dec 29, 2009 11:26 pm
by Steve_t647
Every muffler is different, some packed with steel wool some packed with fibreglass. Then you have the internal hole size in the exhausts, length of tubes etc, as women say size does not matter
in this case it does not design does.
Sorry to say they are all built to different specifications, the skyline one may have good flow and low noise as it was from a performance engine.
As far as spark arresters go the spark is heated carbon making its way through the system this carbon (soot) can be thin flakes in the exhaust on the other side of the muffler shaken loose. so you still need a spark mesh.
More needed on diesels and motorbikes because of higher egt's but insurance would be unhappy if you were not using one.
Just my 2c
Re: muffler talk
Posted: Wed Dec 30, 2009 9:38 pm
by new2zukes
hey thanks for the info, good to know what time looking at, will just find a skyline or subaru muffler no reason why i have just heard they are good stock mufflers.
Re: muffler talk
Posted: Thu Dec 31, 2009 8:33 am
by sig
i have just put a couple of 2.5 inch flow sound mufflers on the 40 and they sound shit hot .and cheap as well .$80 each .they do different sizes as well
Re: muffler talk
Posted: Thu Dec 31, 2009 4:15 pm
by new2zukes
sig wrote:i have just put a couple of 2.5 inch flow sound mufflers on the 40 and they sound shit hot .and cheap as well .$80 each .they do different sizes as well
hey what do you mean by a couple? thanks.
Re: muffler talk
Posted: Thu Dec 31, 2009 6:46 pm
by safaripete
new2zukes wrote:sig wrote:i have just put a couple of 2.5 inch flow sound mufflers on the 40 and they sound shit hot .and cheap as well .$80 each .they do different sizes as well
one either side
Re: muffler talk
Posted: Thu Dec 31, 2009 10:09 pm
by sig
Re: muffler talk
Posted: Thu Dec 31, 2009 10:20 pm
by niblik
lookin to run a 2.5 inch coby on my application.. just wonderin whether one coby will be suffice or use them both..
anyhoo...
Re: muffler talk
Posted: Fri Jan 01, 2010 10:36 am
by SMOKEY
Nibz, I wouldn't buy the muffler yet, It might be rusted out before you need it
Nibz , just pulling your left one
, your builds coming along nicely.
I have a short 2.5" Coby on "OLD SMOKEY" and to my old ears she's as -----
QUITE AS F##K,
FITZY
PS, with the hair dryer on the old 3B a straight pipe will be fine,
you won't hear the exhaust noise over the DARK BOY'S
Doff Doff Doff ------ SOUND SYSTEM,
Re: muffler talk
Posted: Fri Jan 01, 2010 8:00 pm
by niblik
SMOKEY wrote:Nibz, I wouldn't buy the muffler yet, It might be rusted out before you need it
QUITE AS F##K,
FITZY
lmao!! cheers smokey ya cheeky beggar..
and i dont need to buy em, i already got them..
and theres nothing wrong with doof doof fella..
its in my blood..
Re: muffler talk
Posted: Sat Jan 02, 2010 12:22 pm
by new2zukes
well i have 2 zuke mufflers sitting at my place so thought id cut one open to have a look, it seems to have no trace of fibreglass steel wool or any other sound proofing thing but it has 3 compartments and presume this is to limit noise, i also would say it restricts the exhaust gases too as it has to go round alot of corners. if someone knows more id be realy interested. i presume welding a 2.5inch pipe over input and output would be a bad idea due to flow restrictions? well here is a pic of what i found.
Re: muffler talk
Posted: Sun Jan 03, 2010 7:13 pm
by Steve_t647
this muffler is a multiple resonant chamber design they are a lot larger than coby style units.
I think the "baffle" design uses the soundwave collisions to break each other down and cancel each other out.
Not sure I used fibreglass ones on the bike
Re: muffler talk
Posted: Mon Jan 04, 2010 11:32 am
by new2zukes
well i have decided i will make my own muffler as i have all the steel to make one i just need the wool so i found this stuff on trademe.
http://www.trademe.co.nz/Trade-Me-Motor ... 949653.htmi will get a bit of panel steel and make a tube then make 2 cone shapes for each end then get a bit of 2.5inch pipe and drill alot of holes in it then pack with fibreglass wool then weld it all up. i have also seen someone make one on pirate's. i also dont have much room to put a muffler as it is sitting inbetween the g/box and the chassis rail.
Re: muffler talk
Posted: Mon Jan 04, 2010 11:35 am
by niblik
dude.... why make one?
surely its easier to go into someone like magoo's and buy a cheapy? hell, even go through a wreckers for one that'll suit..
Re: muffler talk
Posted: Mon Jan 04, 2010 12:27 pm
by new2zukes
well as i seem to change my mind like the wind i have decided to go with a flowsound muffler. i decided i already have enough things to do without adding another thing to the list.here is the listing
http://www.trademe.co.nz/Browse/Listing ... =262478263
