You can see gap above tie rod nut.
Pajmad wrote:That Circlip can be replace with a normal circlip, they hold on better, If the brass ring has worn out it may have fallen down when you released the cv and is now jamming, push the cv back and see if it has, you may need to release the top ball joint to get it back far enough to see, also when you took the auto hub off did ya line up the keyway in the back of it with the stub groove, they will still bolt up missalingned bt they bend the keyway and stick out a bit making it impossible to get circlip on,
