Oil Leak between Engine and Gearbox
Posted: Sat Jan 02, 2010 7:11 am
Hi
Ever since putting the v6 holden engine into our truck it has had a slight oil leak between the engine and gearbox.
Engine is a ecotec v6 holden and as far as I understand the auto is the standard holden auto.
The oil is black so guessing it is leaking out the rear seals.
Question is, is it worth pulling out and fixing or just keep topping up with oil??
The truck is not a daily driver (prob only used 1 or 2 times per month) so not worried about oil consumption, and is only leaking when engine running therefore not going through a massive amount of oil.
Getting the engine out is going to be a bit of a job as the truck was built around the engine etc, but if needed will be able to jiggle it out.
Anythoughts, suggestions, advise welcome.
Stu
Stu
