Found this on the mighty www......though it interesting
remove the top of the boost compestation device ( top of the diesel pump) and you will find a diaphram, mark the original position then rotate it 90degrees clock wise
if you brave you can lift out the diaphram (noting position) and you will find a star wheel, turn this 180degrees clock wise then refit the diaphram/pin ass to the new 90deg position had earlier.
rotating the diaphram will increase the fueling under boost a lot ( i have mine turned 45deg)
rotating the star wheel will lower the tension of the diaphram and let the boost fueling increase come in earlier
4D56T mods
Re: 4D56T mods
The heads on those engines are fragile enough without doing that. Be carefull you don't end up with a cracked one.
Re: 4D56T mods
Mine just blew a head gasket thinking about power increase
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
?????NEXT?????
06 306 6098
021 02759048
