Several roolovers of the buggy, a couple of rear axles broken and a couple of crown wheels and pinions broken. Oh forgot the best, Rick's jeep did a massive rollover down the bank, probably a write off. Stu was driving.
Got to test the crawler gears out, awesome should of done it years ago. Only bank I couldn't get up was the vertical one the buggies were doing. Didn't see any "normal" 4wd trucks do it either. Crawler gears and twin locked=virtually unstopable. Al
Pommy Ricks truck wasn't running. I hope someone else took some pix of the roll overs. Which vertical slopes are you taking about Al? I didn't do any of the slopes near the trees but did all the others. There wasn't a slope me truck couldn't climb. It just purred up. Beadlocks at 8psi helped. But never used the front lockers on any slopes. I was stoked. The kids had fun. Rach crapped her self tho. Wish I could of stayed longer.
Spoke to Rick earlier. Surprisingly enough he was in a good mood. But he was gutted Keith's roof he was using on his Jeep is stuffed. Stu is fine. He'll bounce back from getting it wrong I'm sure.
A lot of damage but far from a right off. It still a runner. Needs a front windscreen, two front guards and the bonnet straightened.
