hilux diffs into blizzy
blizzyman
Stropper
Post by blizzyman »
ok so i now have hilux diffs in my blizzard all mounted etc, just waiting on getting driveshafts machinced, am wondering though do i need that bar looks like it stops the diff twisting on it self? o also did leaf over diff conversion so its nice and jacked now
pics
Shot at 2010-01-03
Shot at 2010-01-12
Shot at 2010-01-12
Shot at 2010-01-12
Steve_t647
Re: hilux diffs into blizzy
Post by Steve_t647 »
Are you using Hilux push pull steering (standard Hilux) or Crossover steering (surf style power steering box)
If you are turning the passenger wheel then the axle tramp bar is not needed if you are turning the drivers wheel (standard) then you do need it to stop power and brake application throwing you into traffic or parked cars
blizzyman
Stropper
Post by blizzyman »
o yeh sweet its the standard blizzard steering which goes across to the passenger wheel 1st then goes across to the drivers, that explains why blizzard didnt have one, but what i cant understand is why the blizzard had a pan hard rod i didnt bother putting that back in as it looks to restrict suspension travel, not that i have much from leaves but ...
Andrew1706
Post by Andrew1706 »
Blizzards are factory crossover type.
What are you doing about the driveshaft angle from the offset transfer case to the centre hilux diffhead?
blizzyman
Stropper
Post by blizzyman »
nothing haha it wasnt a massive differance so i havnt been to wooried about it, universal will just take a bit of punishment ha, but if it does become an issue ill just chuck a hilux box in it
