discovery two xtra seats
Im looking at buying a disco, i want a 7 seater but i have found a cheap 5 seater. How hard/costly is it to put the two back seats in?
The seats are a bolt in jobby.
What colour interior is the Disco you found? Blue or Tan?
I've got a mate with a Disco with a blue interior and I am pretty sure he has already removed these seats. So there is possibly two cheap seats if you want them and they are the right colour.
- hinsonberger
- Bush Crasher
They used to be approx. $800 for both seats, all fastenings & belts from the LR wreckers around the place. There was a set on TradeMe, but that was probably a year ago now.
Should be simply a bolt in job.
Not sure on legalities, but unlikely for anyone to actually question you on it??
Ninety 2.5P
Discovery 300Tdi
Discovery 300Tdi
There is currently a set on Trade me.
http://www.trademe.co.nz/Trade-Me-Motor ... 998688.htm
Bloody expensive but then this guy seem to try and sell all his Land Rover bits for near a million dollars each.
Darn sure you can get these much cheaper than this with a little patience and shopping around.
But then again, I am a Dutchman, I like things cheap.
- hinsonberger
- Bush Crasher
The other things I forgot to mention were:
- blue seats should be cheaper than grey or tan
- the price I quoted was from about two & a half years ago when a mate priced them up. They should be cheaper by now
- not sure if the 7 seaters had higher rate springs in the rear? The overall payload of 5 & 7 seaters is the same, however, spring rates might be different between the two models?
Ninety 2.5P
Discovery 300Tdi
Discovery 300Tdi
Guidance on the rules here:
http://www.lvvta.org.nz/SeatbeltAnchorages.pdf
and here:
http://www.lvvta.org.nz/SeatAnchorageStd01Oct2004.pdf
Alternatively - do what I do - I've fitted corrolla seats in the back of my FJ40 - did it properly by my standards - high tensile bolts & good backing plates on all the mounts. I've rolled it with passengers in the back & there was no hint of movement so I obviously did it OK. I just pull the seats out when I go for a WOF. Otherwise it would need certification...
and here:
- Aaronoffroad
- Newbie
