SOME 1995 LWB Rear Suspension Measurements.
For all Suzuki related topics
kernels
Post by kernels »
Hi guys, browsing through the forums, I haven't found a lot of measurements and information for LWB Vitaras. Here are some measurements from my rear suspension just in case someone is looking for some info.
Coil Spring Length = 330mm (8.5 coils with 12mm diameter)
Top OD = 95mm
Top ID = 73mm
Btm OD = 106mm
Btm ID = 83mm
Stock Shock max length = 540mm
Stock Shock length on level ground = approx 470mm
Spring length on level ground = approx 240mm
Total wheel down travel between level ground and when the shock tops out = 60mm
I will take the front apart this weekend (as long as it's not p1ss1ng down) and post the measurements.
Hein B
North Shore, Auckland
Return to “Suzuki”
