Which Battery?
Posted: Mon Feb 01, 2010 5:08 pm
by motorhead
Which battery is for starting and which for accessories? Dead battery last nite, this morning swapped batteries around and started fine. Went out and got a new 730CCA one to replace bad one but which one is bad?
Re: Which Battery?
Posted: Mon Feb 01, 2010 5:13 pm
by badnuz
the one you took out is the bad one lol!!
what 4wd is it in?
Re: Which Battery?
Posted: Mon Feb 01, 2010 5:22 pm
by motorhead
badnuz wrote:the one you took out is the bad one lol!!
what 4wd is it in?
90 Paj LWB 2.5TD Factory dual batteries, 12v
Re: Which Battery?
Posted: Mon Feb 01, 2010 5:29 pm
by chevrolux
go to supercheap and get them to put thier tester on it. Or just chuck a multimeter on it and see if one reads lower. although they could both be at 12v which is why the tester that supercheap have is good because it gives you a 'health' reading which i assume is to do with the cranking amps.
Re: Which Battery?
Posted: Mon Feb 01, 2010 5:31 pm
by northland_pajero
I have a 2.8 gen 2 pajero, twin battery 12 volt.
The batteries died, wouldnt start, not enough 'go' so the relay wouldnt let them try. Once started they wouldn't hold charge overnight, I replaced them both, 4 months ago no problems since.
Individually they seem to hold enough charge to run my electric fences, but in dual not enough to start a diesel.
I had heard replace both at the same time as the 'good' one won't last much longer.
Re: Which Battery?
Posted: Mon Feb 01, 2010 7:23 pm
by skid
I might know a battery man
if that helps
Re: Which Battery?
Posted: Mon Feb 01, 2010 7:29 pm
by NJV6
The battery closest to the front is the main one on a Paj. Most poeple in NZ get away with just one battery (the front one) - the dual batt ones came from the snowy areas in Japan.
Re: Which Battery?
Posted: Mon Feb 01, 2010 10:20 pm
by motorhead
Thanks for the info, I think Battery in back is now the defective one so I will have it checked to be sure. Will put new battery 730cca in front and older 580cca in back until I feel I need to replace it.
Skid, I was unaware of your voltage connections
, will check with you before I replace second one
Thanks all
Re: Which Battery?
Posted: Mon Feb 01, 2010 10:31 pm
by Jerry
Skiddy has a battery checker thingy as well....
Re: Which Battery?
Posted: Mon Feb 01, 2010 10:40 pm
by motorhead
Don't really want to hear about Skiddy's thingy
Thanks for the offer
