33 tyres on kzn130 surf off set wheels?
Sausage
Post by Sausage »
Evening all
body lifting my surf this weekend and have some 33 comming to put on it have heard and seen 33's on standard wheels but unsure if they rub or anything so my question is will standard wheels work or do i need different off set to prevent rubbing and any other problems?
Thanks
Lynx
Re: 33 tyres on kzn130 surf off set wheels?
Post by Lynx »
You shouldnt have to bodylift your surf to fit them, and a body lift can work out to be more hassle that its worth, cracking/broken mounts and the such.
Sausage
Post by Sausage »
really? i didnt think you could fit 33's with the standard height well not without alot of rubbing everywhere? either way can standard wheels work or need a bigger off set to go from 31x10.5x15 to 33x12.5.15?
Thanks again
UBZ
Post by UBZ »
standard 15 x7 alloys have 0 offset. never tried it, but id say with the factory alloys and 33's it would rub all over the place
ideal would be 15x8 , -19 or -24 offset steel rim and tubes to sit the tyres outside the flares just.
33's will fit with just a 2inch body lift, stock suspension and a bit of persuasion with a BFH to the inner guard behind the front wheel.
as far as i know 33's wont fit without a body lift unless you cut out the guard / firewall behind the front wheel and weld in a new plate to cover the hole.
whitetrash
Post by whitetrash »
Lynx
Post by Lynx »
I Have 33x13.5.16 Mudzillaz on steel rims on my 130, no lift, only rub on full lock.
